NA manifold
NA manifold
Found this difficult to search for as can't do less than 3 chars in the search so "NA" is out.
Does the XU NA intake manifold fit ?
I'm guess not else more people would use them, or are they just very restrictive and that's the reason ?
well, first answer is i dont know
what are you trying to acheive? - if its a non-IC manifold then the xantia diesel ones come without the intercooler bollox on top of it..
/Toseland
But they sit above the valve cover.
Need to avoid that Smile
I'm gonna take a guess and say your talking about the xud nad intake and not the gti one as that deffinitely wouldn't fit lol
Yeah, good point. XUD not XUD turbo.
The early xud non turbo, some were a metal inlet which came over the rocker, bit like my 2.1 intake does...
It will fit yes...xantia mani will do same job with less metal though
What about the real Early intakes, like on the original XUD7/9 in the 205/305s etc
[Image: xud7l.jpg]
Thats got nothing over the cam cover...bar the intake pipe.
C15 citroen van also had the right fanimold to fit a FMIC to.
(11-07-2014, 03:53 PM)mr_fish Wrote: What about the real Early intakes, like on the original XUD7/9 in the 205/305s etc
[Image: xud7l.jpg]
They're on the square port engines far as I'm aware, so won't fit...
Ah, ok so there are some square ports then.
If that wasn't square it would possibly be ideal. Nothing over the cam cover is best. Can route the pipe out to the side.
Vaux/Isuzu 4EE1 engines, you can swap the intake inlet to either side. Very handy when going FMIC Smile
