Post mot
Just had my MOT and was extreamly suprised to find out it has passed with some observations. First time ever.
I'm trying to find out if the is a bush replacement kit I can buy to replace some of the bushes that are warn anyone got any ideas of where I could get them from?
What bushes have been noted? Take a pic of the advisories or write them down here word for work and we can advise you on what needs doing
004 Inner front lower (rear) suspension arm rubber bush deteriorated but not resulting in excessive movement [2.4.G.2]
005 Rear (n/s and o/s front) sub-frame has slight play in a pin/bush [2.4.G.2]
Sounds like the P bush on the wishbone. You can replace those with Partner P bushes which last longer.
And I'm not sure about the 2nd one, I'd guess that's the forward rear beam mounts but seems an odd way of putting it!
