26-05-2014, 12:20 PM
Does any one have any pictures of a g/box mounted turbo setup, im thinking about doing it to my hdi? Also does anyone have and parts or ideas that might be useful?
Gearbox mounted turbo
26-05-2014, 12:23 PM
There was a thread a little while ago, same question asked, and loads of pics of gearbox mounted setups...try a search and see if you get anything
26-05-2014, 12:32 PM
I didnt think there was.much point on a hdi unless you going huge power? You can mao them with minor mods and clutch to good power. I thought it was more of an xud thing
26-05-2014, 12:36 PM
I was planning to put a bigger turbo on due to the standard one failing, i guess that it means i can easily run 22 psi boost and be fairly reliable doing it, 20psi is the max on a k15.
26-05-2014, 01:16 PM
Here was my set up [attachment=16466]y[attachment=16465][attachment=16464] let me no if u need more pics have loads lol
26-05-2014, 01:38 PM
looks good mate, did i take much making the pipe from the manifold to the turbo? did the exhaust run ok and how did you do it?
26-05-2014, 01:59 PM
If you want to see it on a dq 10 engine have a look at brynllwog (sp) project thread.
26-05-2014, 02:05 PM
Have you got a link uberderv, i cant seem to find it on the search
26-05-2014, 02:15 PM
26-05-2014, 02:22 PM
You can get a decent upgraded turbo down the back on a hdi which would be good for 200bhp...
Which is more than your standard clutch will manage Wishes for more power...
26-05-2014, 02:43 PM
So what turbo would you all recommend to fit then? Thanks uberderv for the link
26-05-2014, 03:51 PM
Apparently the turbo off a 120d is a goodun, it's a 3rd gen VNT so will require some special mapping.
26-05-2014, 05:02 PM
A VLKR would be wonderful...but a simple GT1749/52s would be a simple ish swap and would see very good gains without having to find some random turbo for £300 off a 120d and without having to control it and you can find them for about £70-100
26-05-2014, 05:56 PM
(26-05-2014, 05:02 PM)Piggy Wrote: A VLKR would be wonderful...but a simple GT1749/52s would be a simple ish swap and would see very good gains without having to find some random turbo for £300 off a 120d and without having to control it and you can find them for about £70-100 You saying not to go VNT with ecu control?
26-05-2014, 06:19 PM
26-05-2014, 07:59 PM
Where do you pit the battery?
26-05-2014, 08:02 PM
26-05-2014, 08:05 PM
Aaah!! I am leaning towards box mounting my td04 purely so I can go vnt sooner or later. Fab work will be easy for me
27-05-2014, 05:48 AM
I shouldn't bother with the gt17s, they're too small or laggy to be worth it imo. VNT would be ideal if you can find someone to map it, pro_steve does vnt control these days.
27-05-2014, 01:10 PM
Didnt take me that long and the pipeing wasnt than hard ether my point is is ur going for a bigger turbo u are goin to want people to be able to see its so that why i went gear box mount lol :-) bt is up to u like :-) [attachment=16477] [attachment=16476]
27-05-2014, 01:53 PM
(27-05-2014, 05:48 AM)Poodle Wrote: I shouldn't bother with the gt17s, they're too small or laggy to be worth it imo. VNT would be ideal if you can find someone to map it, pro_steve does vnt control these days. Laggy!? GT1749s I wouldnt ever say was laggy! Wishes for more power...
27-05-2014, 01:59 PM
That relocation pipe above looks like a right radge :S
![]() Diablo Meridian HDi - 125bhp - 73.0MPG - Halfords Wheels
27-05-2014, 02:19 PM
27-05-2014, 02:30 PM
I know they're not exactly precision engines, but that's going to introduce some resistance to flow!
27-05-2014, 02:31 PM
27-05-2014, 02:33 PM
I specifically mean the join from the straight to the pipe that goes to the hotside BTW, the rest seems perfectly functional
![]() ![]() Diablo Meridian HDi - 125bhp - 73.0MPG - Halfords Wheels
27-05-2014, 04:31 PM
![]() Lol the pipe in the pic was just a tester its a lot better nw lol and works fine :-)
28-05-2014, 05:42 AM
31-05-2014, 09:50 AM
(28-05-2014, 05:42 AM)Poodle Wrote:(27-05-2014, 01:53 PM)Piggy Wrote: Laggy!? Remember though laggy =/= high boost threshold... Two very different things... I've got a 1752 on my DT atm, once you've got it above 3k rpm, you can poke the throttle and the turbo is instantly there, anything below 3k, just not enough gas flow... That's a high boost threshold... Conversely a T25, starts spooling from about 1400rpm, but takes an age to build to full boost - that's lag. Every time you get back on the throttle, it takes an age for the turbo to spin up to speed.
31-05-2014, 09:23 PM
So is lag just due to the inefficiency of the turbine/inertial/friction losses? Obviously boost threshold is a design feature, as a turbo has a set operating range.
![]() Diablo Meridian HDi - 125bhp - 73.0MPG - Halfords Wheels |
Gearbox Mounted Turbo | TommiePuglet | 22 | 7,961 |
06-10-2017, 06:15 AM Last Post: TommiePuglet |
air filter mounted on turbo? | mattydturb | 2 | 1,174 |
16-01-2015, 09:34 PM Last Post: Jonny81191 |
