Will this fit a Ph2?
http://www.ebay.co.uk/itm/321210823520 in desperate need of a idle control valve, will this fit my Ph2 it's says it fits 1.4s so I'm presuming it will fit mine?
If your engine is a TU3MC then yes, should fit. Compare it to yours that is currently fitted. Sometimes the bolt holes can differ. Best way to check is visually Smile
(25-05-2014, 02:58 PM)Grant Wrote: If your engine is a TU3MC then yes, should fit. Compare it to yours that is currently fitted. Sometimes the bolt holes can differ. Best way to check is visually Smile
Bolt holes look the same how do I know if mine is TU3MC?
See below Wink
(25-05-2014, 03:04 PM)Grant Wrote: See below Wink
Mines a 1999 1.4 so will mine be a TU3JP?
From using the above table, I would have said so, yes Smile
(25-05-2014, 03:13 PM)Grant Wrote: From using the above table, I would have said so, yes Smile
So this idle control valve should fit? If not I'll have to get one from ECP so I'll know it fits
Just because you get it from ECP it doesn't necessarily mean it will fit. I've been incorrectly supplied a few times myself.
My bet would be to put your reg into the ECP website, get a part number for the product it states, then compare it to that in your eBay link. That will then give a *better idea* if it is the correct item
(25-05-2014, 03:50 PM)Grant Wrote: Just because you get it from ECP it doesn't necessarily mean it will fit. I've been incorrectly supplied a few times myself.
Yeah I just typed my reg into ECP and it gave me the engine code for my car (TU3JP KFX) so I'll go for that one on ECP Smile
I went down to the scrappers and got a few for a quid each! See if you can get one from a scrap yard.
I seem to remember there are two versions. one where the bolt holes are opposite each other and another where they are both skewed off to one side.
(27-05-2014, 06:00 PM)SRowell Wrote: I went down to the scrappers and got a few for a quid each! See if you can get one from a scrap yard.
Spoke to Euro Car Parts earlier and I found the exact one I need Smile it's £68.29 so a little pricy haha but I need it so I can drive it properly. I'm getting insured tomorrow Big Grin all ready for FCS
