Threads: 66
Car Model/Spec: 306 hdi Dturbo
Ok, so I fancy a 20mm drop front and match it on the rear, I've heard through the rumour mill that xsara vts shocks and springs will drop the front 20mm and be stiffer?? Has anyone tried this and are they a direct replacement as I'm told?
I have a hdi so would the heavier weight of the Diesel engine differ on the petrol springs?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
or citroen zx volcane TD shocks/springs - direct replacement, 15/20mm drop and slightly stiffer than standard.
have a set here if any interest
Threads: 66
Direct fit? Or a bit of faffing to replace 306 shocks?
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
Xsara VTS springs do indeed do what you're wanting - that's what I'm running on my HDI hatch.
Threads: 66
Is there a specific year I would require to fit to my 2000 hdi d turbo?? And thanks guys starting to enjoy the forum experience and help and tips
Threads: 66
I've got a 3 door 2.0hdi dturbo phase 3 looks exactly the same as a gti6
Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Yeah, dturbo is already slightly lowered, is the zx lowered even further?
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Threads: 87
48
(22-05-2014, 10:36 PM)thebluepearl1 Wrote: Ok, so I fancy a 20mm drop front and match it on the rear, I've heard through the rumour mill that xsara vts shocks and springs will drop the front 20mm and be stiffer?? Has anyone tried this and are they a direct replacement as I'm told?
vts engine is slightly heavier than our diesel lumps actually, so they lower it slightly less, i run xsara vts springs and i think it's a nice subtle drop . .
Threads: 66
So how do I find out if I'm running non OEM shocks @dee turbo if be intrigued to check maybe just a case of changing back to OEM
Threads: 66
Cheers will check when I get the car home, would be nice to improve the ride height a touch if it is running the wrong shocks.
Threads: 162
21
FYI The dampers are £80 each from the dealers.
Threads: 66
Ok deeturbo thanks, my old man has numerous trade accounts with different motor factors so will get them at his trade price anyways, kind of lucky in that way as I don't have to pay joe blogs price
