09-05-2014, 07:38 PM
As above any clues 02plate thanks.
206 steering wheel removal
09-05-2014, 07:40 PM
Remove battery
Remove airbag Remove torx bolt from centre Pull like f*ck. Think that's it ![]() TEAM CONROD SHITTING RALLYE!
09-05-2014, 07:44 PM
(09-05-2014, 07:40 PM)Matt Wrote: Remove battery no no no! . . . leave the torx bolt in by a few threads, so when it comes out you don't get smashed in the face . . ![]()
09-05-2014, 07:49 PM
Magic give it a go many thanks ,hoping something a miss with the transponder wire as car gone dead .into econ mode cooking thing ,its the last resort before its go to the scrapyard .
09-05-2014, 08:06 PM
Removing the airbag is a bit tricky. On each side behind, there is a hole with a spring clip behind it. You need to use a flat head screwdriver to push them in and the air bag will pop out. Need to give it a proper wiggle. Once off, disconnect both airbag connectors and the horn earth and then it's straight forward from there. Undo the BFO torx bolt but leave it in about 5 threads and smash it towards you. If you don't, it will come flying at you and smash you in the grill I promise lol
09-05-2014, 08:07 PM
(09-05-2014, 08:03 PM)Matt Wrote: Buy where's the fun in that Matt? sorry . . .i'm a real killjoy i know . . ![]()
09-05-2014, 08:08 PM
Give the wheel a smack towards the dash to loosen it a tad.
My 306 wheel needed a smack in both directions too loosen it off the splines ![]() TEAM CONROD SHITTING RALLYE!
Its a pity I wasn't smacked in the face before I bought this heap shit,frigging pugs . up
09-05-2014, 08:09 PM
(09-05-2014, 08:08 PM)molly Wrote: Its a pity I wasn't smacked in the face before I bought this heap shit,frigging pugs . up woah . .thereeee hossi, don't tar us with the 206 brush thank you kindly . . ![]()
09-05-2014, 08:19 PM
Soz but I've got two pugs witch are dead :306 as well what needs alternator all un done but can't seem to get pass the p/steering bracket ,
09-05-2014, 09:16 PM
What 306 is it? Sure we can help you out. There are a lot breaking atm
09-05-2014, 09:26 PM
02 hdi meridian
Steering wheel switch | Niall | 11 | 2,648 |
08-03-2015, 07:51 PM Last Post: Eeyore |
