Threads: 226
24
Car Model/Spec: A3 TDi
Hi all i adjust my wastegate today im im trying to up the pressure and get some more power buuut i adjusted it and i only got to 1.5bar once :/ i want that all the time.. so do i have to turn the fueling up now or is there some trick because its already smokey on full chat??
Threads: 150
14
Car Model/Spec: 306 HDI
What turbo and fuel pump have you got?
306 HDI, soon to be XUD
Threads: 171
46
yeah turn the fueling up, youll get it up a bit more
more exhaust gasses more to spin the turbine?
Threads: 226
24
I have a t2 and a bosch pump  Its smokey on full chat anyway though so surely more fuel would just be wasted?
Threads: 171
46
oh right? so whats it boosting at now then? when its smoking on flow?
Threads: 150
14
Good combination then
And you need to turn it just enough to get the peak power, anymore than that and your just pissing away diesel
Threads: 226
24
About 1.2 on average :/ But now the wastegate is adjusted i know the fuel side is holding it back just never understood how it works... Wheres Ruan or Darren when you need them lol
Peak power would be more pressure which i havent firgured out how to get yet  haha
Threads: 171
46
adjust the wastegate more?
Threads: 226
24
But the wastegate wont open til after my 1.5 target atleast so it would make bugger all difference i assume :/
Threads: 171
46
get a mbc in there  set that to the 1.5 then no need to worry about the WG
Threads: 226
24
That's not my problem for a minute lol i want more power!! Might fit an MBC in the future but not yet..
Threads: 171
46
tomw1123 Wrote:That's not my problem for a minute lol i want more power!! Might fit an MBC in the future but not yet.. why not yet? no time like the present?
Threads: 150
14
MBC go for quite cheap dont they?
Threads: 171
46
declantg Wrote:MBC go for quite cheap dont they? BIN ones on ebay for about £18
Threads: 150
14
Whats the advantage of having one?
Threads: 171
46
declantg Wrote:Whats the advantage of having one? i used to get this all wrong but now i have seen the light
they go between the compressor and wategate, normall the wategate would know the pressure on the compressor side then when it reaches a certain pressure release the wategate channeling exhaust away from the turbine to lower compression
mbc controls what the wategate THINKS the pressure is at so it will tell it when it gets to your set pressure, so then the wategate opens when the mbc wants it to
Threads: 150
14
4WayDiablo Wrote:declantg Wrote:Whats the advantage of having one? i used to get this all wrong but now i have seen the light
I understood this  thank you
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
/facepalm ... dude you should really read and understand the basic principles before fiddling imo.
Phaes 1 GTI 6 - Onyx Black
Threads: 171
46
ginge191 Wrote:/facepalm ... dude you should really read and understand the basic principles before fiddling imo. i just go head on into it lol break it then fix it then understand it
Threads: 226
24
ginge191 Wrote:/facepalm ... dude you should really read and understand the basic principles before fiddling imo. Thanks for that unhelpful post :clap:
Threads: 226
24
Cheers 4way guess i'll have to turn the fuel up tomoorrow and see what happens.. i need to bend and chop bits off the throttle arm to keep the idle down lol
Threads: 171
46
wouldnt turn it up too much f your already smoking on peak boost
Car Model/Spec: 306 D Turbo
4WayDiablo Wrote:wouldnt turn it up too much f your already smoking on peak boost
^This X 100
If there is already black smoke on full boost then adding more fuel will just produce insane egt's, this is what will melt things. If I were you I would get an MBC as said already or give a few more turns on the wastegate.
If you still cant get anymore boost then start looking for leaks. My T2 will hold strong at 28 PSI.
Threads: 226
24
londondan86 Wrote:4WayDiablo Wrote:wouldnt turn it up too much f your already smoking on peak boost
^This X 100
If you still cant get anymore boost then start looking for leaks. My T2 will hold strong at 28 PSI. Best get the soapy water out tomorrow then lol :roll:
Threads: 171
46
You should hear a boost leak if its that bad!
Threads: 226
24
My boost gauge makes some noise but apart from that i dont know lol... soapy water will help me find it aswell instead of just trying to listen for it and locate it
Threads: 541
124
Id say you have a boost leak mate. A T2 will run 2bar smoke free on a bosch.
Have a look at your intercooler d-seal and the first pipe to come off the turbo, theyer the common ones.
Also If you dont want to keep adjusting the wastegate and want to run silly boost then you can just unplug the wastegate and block the hose off.
That way your boost is controlled by your fueling.
Threads: 226
24
I had a new d seal about a month ago and covered everything in washing up liquid this morning and no bubbles so im stumped... I seen on .net about maybe trying to tighten my inlet manifold?? that worth a go?
Threads: 541
124
It could be its only leaking over a certain threshold of pressure. You wont hit anywhere near full boost unless your driving and you cant look in the bay if your driving.
Threads: 226
24
How do i find them then??lol
I had the intercooler off today tightened all the manifold bolts there was a bit of slack to them but not anymore... then the bastarding f*cking d seal went and popped out so cleaned all that up and cut and shut then i put some hylomar gasket sealing crap there so its not that went for a drive and same boost again :cry:
So none of that was the problem.... im going to order a proper boost t piece as mine isnt very good then see what happens after that :?
