Could fix it?
Could fix it?
Drove my car to get the clutch done last week and I noticed it drinks fuel pretty quick and has hardly no power, I've heard that this could be the lambda sensor?
yeah could be, the TU's are pretty simple comapred to some engine setups, lambda/temp/map are basically it but the lambda is probably the most likely culprit,
how long is it since it's last service?
Project: Formula Peugeot
(05-05-2014, 07:40 PM)John1.4 Wrote: yeah could be, the TU's are pretty simple comapred to some engine setups, lambda/temp/map are basically it but the lambda is probably the most likely culprit,
Never came with a service history so I'm gonna do a service and see if that helps, if not then I'll replace the lambda. Just ordered a fuel filter so need to find out where it is on the car and replace that
The fuel filters on the under side by the drivers side rear door
