05-05-2014, 04:40 PM
Drove my car to get the clutch done last week and I noticed it drinks fuel pretty quick and has hardly no power, I've heard that this could be the lambda sensor?
Could fix it?
05-05-2014, 07:40 PM
yeah could be, the TU's are pretty simple comapred to some engine setups, lambda/temp/map are basically it but the lambda is probably the most likely culprit,
how long is it since it's last service?
Project: Formula Peugeot
05-05-2014, 09:20 PM
(05-05-2014, 07:40 PM)John1.4 Wrote: yeah could be, the TU's are pretty simple comapred to some engine setups, lambda/temp/map are basically it but the lambda is probably the most likely culprit, Never came with a service history so I'm gonna do a service and see if that helps, if not then I'll replace the lambda. Just ordered a fuel filter so need to find out where it is on the car and replace that
08-05-2014, 06:03 PM
The fuel filters on the under side by the drivers side rear door
