Threads: 10
Ive got ta technix coilovers on the front at the moment and they seem to make some kind of bouncing noise would this be because I've got standard top mounts on?
Im debating on getting some kyb top mounts off ebay? Are they any good??
Threads: 141
35
Kyb are Oem on most cars these days including Peugeot iirc.
I've noticed that ta technics do seem to have a habit of eating through topmounts though so worth changing if the rubber has began to perish
Threads: 10
Ok cheers ill probably get a set then.
And with the rubbers ill have to have a look. Would that explain the bouncy kinda noise?
Threads: 27
Car Model/Spec: Ph1 xrdt
Dont forget bearings when changing top mounts. Worth doing for the extra £10
Threads: 10
Ive got a feeling they come with the bearings but ill double check. Thanks
81
Probably just TA Technix tbh.
Threads: 10
Cause there cheap yeah aha
Threads: 0
Car Model/Spec: China blue phase 3 hdi
I had to change mine last weekend with the same problem
