Threads: 213
Car Model/Spec: HDI
29-04-2014, 01:45 PM
(This post was last modified: 29-04-2014, 01:46 PM by MY95.)
As above?
It sounds quite good but is around 10 year old now. Im either upgrading or putting back in the standard items as they are better for power I beleive
[attachment=15840]
Threads: 42
28
not a proper gti6 one, looks like one for a small carb!!
Looks quite restrictive to me, whatever it was/is
Threads: 213
Car Model/Spec: HDI
I thought it looked a bit strange!
What would you guys suggest replacing it with?
Threads: 77
That looks like one that was on my old mini su carb
Threads: 213
Car Model/Spec: HDI
(29-04-2014, 02:12 PM)titch Wrote: That looks like one that was on my old mini su carb
So defo worth changing and not really supposed to be on the car then?
Threads: 42
28
hell yeah, pop a proper filter on and its likely it'll be quicker.
Threads: 213
Car Model/Spec: HDI
29-04-2014, 03:08 PM
(This post was last modified: 29-04-2014, 03:09 PM by MY95.)
(29-04-2014, 02:59 PM)welshpug Wrote: hell yeah, pop a proper filter on and its likely it'll be quicker.
thought so haha, anyone selling one?
Can you use induction kits from the 1.6s and 1.8s or is that rubbish ive picked up?
Threads: 19
Ive got the exact one on my go kart carb. So yeah...get it changed
Threads: 42
28
you need the original inlet elbow even if you fit a proper K&N kit.
Threads: 213
Car Model/Spec: HDI
29-04-2014, 03:26 PM
(This post was last modified: 29-04-2014, 03:27 PM by MY95.)
(29-04-2014, 03:16 PM)mr_fish Wrote: Ive got the exact one on my go kart carb. So yeah...get it changed
haha what a spoon whoever put that on the car!
Cheers for the info!
(29-04-2014, 03:20 PM)welshpug Wrote: you need the original inlet elbow even if you fit a proper K&N kit.
Ok thanks for the info, can i use a 1.6/1.8 induction kit on it? theres no difference is there between hat and a one for a GTI6 engine?
Threads: 102
18
You don't want to end up using a filter that is too small, no idea on filter size differences.
If you buy a kit, it comes with the mounting bracket as well, which if you've bought a 1.6/1.8 kit it will be in the wrong place. Having the original inlet elbow will make your inlet tract longer as well which should help along with a filter that isn't too small and old and clogged.
If you want to retain the nice sound but don't want something restrictive, a universal aftermarket filter from a good brand would be acceptable if you can figure out how to mount it, or the specific K&N 57i for the gti-6 which do pop up for sale every now and then. I run one of these behind an alloy shield.
I do have a BMC CDA for sale but I'm not sure it'd meet your needs as it isn't particularly easy to mount it without moving something else/having the cold air feed from a foglight.
Threads: 213
Car Model/Spec: HDI
(29-04-2014, 03:49 PM)RetroPug Wrote: You don't want to end up using a filter that is too small, no idea on filter size differences.
Thanks for the info!
Im wanting something cheap and easy enough to fit, with decent sound but not so much that it drowns over the exhaust note and also something which isnt restrictive, was thinking of the standard airbox with k&n filter in, or standard airbox with standard top end filter, or something like a pipercross induction kit etc
Threads: 42
28
you need gti6 stuff, its all different.
K&N is a top end filter, dunno why you think a pipercross is higher end
Threads: 213
Car Model/Spec: HDI
(29-04-2014, 05:03 PM)welshpug Wrote: you need gti6 stuff, its all different.
Ah sweet, thanks!
Going to see what available, hopefully a standard airbox
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Before i fitted my charger i always ran a K&N panel filter in the original box , best way IMO, K&N filter for the 6 is pretty cheap
http://www.ebay.co.uk/itm/K-N-Air-Filter...5d3894ca5a
Threads: 102
18
The standard airbox with a good replacement filter is an excellent option.
Threads: 213
Car Model/Spec: HDI
30-04-2014, 02:14 PM
(This post was last modified: 30-04-2014, 02:14 PM by MY95.)
(29-04-2014, 06:06 PM)puglove Wrote: Before i fitted my charger i always ran a K&N panel filter in the original box , best way IMO, K&N filter for the 6 is pretty cheap
Thanks for the info and link!
That is pretty cheap compared to ones for other cars
(29-04-2014, 06:07 PM)RetroPug Wrote: The standard airbox with a good replacement filter is an excellent option.
Cheers
Threads: 102
18
Ran the same filter as puglove and considering returning to it in the std. aribox and agree that it was great.
