few s16 parts left
Here is a few s16 parts I have left
Injector loom, some of the covering is cracked but all of the wires are intact and it worked as it should £10 delivered
Drivers side engine mount buffers, the two triangle ones that the bolt goes through , this is a group n item £15 delivered
Braided brake line set, brand new in carbon fiber effect finish £55
I also have all sorts of sensors , switches etc so if you need and of them let me know I may require an image to cross check with to see if I have them
I'll add more as I come across them
Don't suppose you got any inlet diaphragms?
(23-04-2014, 02:48 PM)Frosty Wrote: Don't suppose you got any inlet diaphragms?
no they went a long time ago.
just trying to clear all my rubbish from peugeot parts out so I can start collecting rx8 and alfa romeo bits instead
Don't suppose you know where I could get some? Peugeot don't do them anymore Sad
(23-04-2014, 03:30 PM)Frosty Wrote: Don't suppose you know where I could get some? Peugeot don't do them anymore Sad
afaik its only them that did them, suppose they are such a low volume part that it wasnt worth the while of any one else.
I got mine second hand from Skip Brown
Still here
Time to clear out need to get some bits for the rx8 rebuild
is that 55 delivered on the lines mate?
(26-12-2014, 09:56 AM)ash23 Wrote: is that 55 delivered on the lines mate?
Yes mate
Is the Drivers side engine mount buffer the same as an hdi?
Cheers Dave
Afaik they are all the same throughout the range
Ok thanks, i don't suppose you have a picture of it?
Cheers Dave
I can get one later for you no problem
if you don't mind please mate, that would be great
Dave
(26-12-2014, 02:28 PM)titch Wrote: if you don't mind please mate, that would be great
Dave
It's the same as this
[Image: 9F145FC1-B329-4310-8F27-C49882C9ECA4_zpsxvaa74yb.jpg]
Mine is buried at the back of the man cave behind all the wrapping from the kids presents, also have the little buffer that sits on top of the center bolt aswell
Mine isn't as rusty as that either
have the lines been posted yet mate?
Pictures of my upper mount buffer.
Looking at Ecp this is the same item on all xu range engines
As you can see there is little to no wear on the buffers.
Also comes with the rubber buffer that sits over the center bint and under the cradle cover
[Image: B2BE8A91-E6A7-4DF0-AF65-4C0EC56A1AFC.jpg]
[Image: CAD76B96-3A2C-42E2-964D-5AEC299915BD.jpg]
[Image: 3DD75B26-6AE9-4F53-A730-981CCDE2F545.jpg]
Thanks
Offers
To the top
Top to the
Also just found an almost mint orginal handbook late hs1 early phs 2 £7.50 delivered
And a brand new still in bag 306 rear boot badge £ 7.50
Any one
  Breaking Ph3 1.4 LX 306 - Parts Left Toms306 33 25,092 19-05-2018, 09:49 AM
Last Post: Toms306
  Parts Left From Breaking - Collection from Ace on Saturday bigcheez2k3 36 19,493 12-10-2013, 04:17 PM
Last Post: Carlos vinyls
  random left over bits more parts added swampy 20 12,027 23-05-2013, 07:00 AM
Last Post: swampy
