Threads: 170
right here goes my car had a lucas pump and t2 turbo. changed to a bosh pump and just changed the turbo as mine was fecked. took it down the road and it pulled better but not as good as i thought and its coaling but the pump hasnt been tuned. could this be down to the air filter as i have a k&n filter but its tiny. im soooooo confuse :think: d
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 87
48
pump timing out maybe mate . . . . .
Threads: 170
how can i find that out?. it was sluggish before only hit 14psi but didnt look last time i drove it. seems better but its not lively and like i say just smokes
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
any one?
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 86
Black smoke smoke means boost leak.
Threads: 87
31
What colour is your smoke Karl? As padge said black is overfuelling (caused by boost leak) and also white/grey smoke is usually retarded timing.
Threads: 170
the smoke is black. ive just put a new Dseal on. im guna check the inlet manifold bolts see if they need nipping up. im guna check that pipe mark see it got a hole in it. hope i find this dam leak
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
could the headgasket cause this?
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 9
19
Given 3 thank(s) in 1 post(s)
Not really no, HG's don't tend to go unless the engine gets cooked, I know mine has popped the turbo end of that hose off a couple of times Karl so its worth checking for sure!
Threads: 170
ye il check it mate. it should be still on cos i tightend it right up. been told it could be my intercooler (TMIC) btw.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
you have what 2 TMIC's. yes ive got a boost gauge fitted
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
well drove the car other day and it felt as in it come on boost abit then just bogged. some one may have had this problem before to help me out
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
guna get another pipe from the turbo as this is really fecking me off now. if still no joy she will be up for sale
Ph3 perv cab heaven
Black ph1 XUD died
