18-04-2014, 09:10 PM
I have noticed the heated mirror doesn't work on the passenger side. Anyone know how to fix?
Heated mirror don't work?
18-04-2014, 09:13 PM
I didn't know any still worked on 306s!
![]() Its most likely the element behind the glass broken (same system as rear window), so new glass should fix it.
19-04-2014, 08:11 AM
or the door loom is broken
19-04-2014, 08:30 PM
(18-04-2014, 09:13 PM)Toms306 Wrote: I didn't know any still worked on 306s! Driver side one works a treat. How much is the glass? I think I have another mirror knocking about somewhere, might nick it out of that one. Is it easy to remove?
19-04-2014, 08:32 PM
Push the glass back at the top and look behind it at the bottom. You will see a small bit of metal wire. Jam a flat head screwdriver in there and pull it down and it will release a wire retaining clip. Then you can just gently use a flat head to pop the glass out of the mirror.
Before refitting, put the retaining clip back in otherwise the mirror will hit the floor first time you go over a bump lol
Nice one buddy :thumbs:
Same problem here. Some kid went by on a bike and knocked it. Always the first things to go on cars, well with me, anyway....if it isn't an MOT issue, I tend to leave it.
20-04-2014, 08:05 PM
Quite the opposite to me then, I fix anything that don't work. Unless its very expensive or benefits vs effort = not worth it.
21-04-2014, 07:00 AM
True HD - I just don't have the skills like you have and wish I did.
| Wiring diagram for heated seats | bebic | 0 | 3,053 |
28-04-2019, 07:30 PM Last Post: bebic |
| electric / heated rx8 seats | ash23 | 6 | 4,412 |
07-12-2014, 02:18 PM Last Post: ash23 |
| Heated Rear Window Relay | Mark | 6 | 4,123 |
05-11-2014, 02:22 PM Last Post: cully |
