XUD Oil Sandwich Plate
Want to get oil pressure / temp gauges, where does everyone take off for readings from? I presume a sandwich plate.
Are they universal to the thread size? What is the thread size?
eBay the usual place to pick one up?
Any tips etc?
Thanks!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Yeah ebay, pretty sure the thread size is M20x something. Just make sure its clean, i had to do up the bolt on the sandwhich plate tighter than i thought i would have to seal it, you need a big socket for that (well its not big, just bigger than my halfords set had) so make sure you have one handy.
oil temp you get from the sump, oil pressure you can add a tee piece to the existing low pressure warning light switch and use a XU5 or 9JA or 9J4 pressure sender, and an o.e 205 gauge.
no need for a sandwich plate.
It's too fit a ph1 306, not too happy about using an adapter sump plug as it's low to the ground so do I just tap into the sump near the bottom?
As for pressure, where is this exactly Mei?
S14 Zenki Build
Above the heat exchanger, theres a small 1 or 2 pin sensor, oil pressure sender, its tapped into an oil gallery. You can get adapters that screw in there and you can drill and tap the sump for temperature... Or you could just get a sandwhich plate lol
The 9JA is the 1.9 gti that welshpug is referring to and the 9J4 is the mi-16 if i remember rightly
Vehicle repair and servicing in the midlands pm for detailsĀ
Current cars
Subaru Impreza 2.0d - Daily
yup.
as for the oil temp, I would drill the sump on the back as per the 205 gti and have an appropriate threaded nut tacked in place, exactly like the gti sump.
or indeed get a 1.6 gti sump with the thread already in place and a sender.
So... What thread is the XUD (D8A) oil filter thread so I can get a sandwich plate..?
S14 Zenki Build
The sand which plate i had come with 4 different adapters, though the thread size is m20x1.5
This is the 1 i got http://www.ebay.co.uk/itm/370799610886?v...1497.l2649
Pretty sure thats what i have aswell ^^^
For oil pressure, there may be a blanking plug behind the starter motor which you can use. No need for a T piece then Smile
(14-04-2014, 07:48 PM)Frosty Wrote: The sand which plate i had come with 4 different adapters, though the thread size is m20x1.5
Thanks buddy, ordered it up.
Now for temp/pressure sensors..
Remember which you got? Or did they come with gauges?
www.ebay.co.uk/itm/370678852601 ?
www.ebay.co.uk/itm/370678745409 ?
What else am I missing?
S14 Zenki Build
Mine come with the gauges but the company that sells the sandwich plate does the sensors as well
  oil cooler sandwich plate adaptor Chris_90 12 7,826 07-02-2014, 12:25 PM
Last Post: Chris_90
  Sandwich plates Danny2009 15 8,499 02-11-2013, 02:38 PM
Last Post: r3k1355
  Standard oil filter on sandwich plate 306Puggy 11 7,202 30-07-2013, 12:44 PM
Last Post: Frosty
