Fitting bike carbs
Fitting bike carbs
this is not for a peugeot engine but the idea should be the same, just want to know what to do about the fuel pump, will i remove it and join the pipe or fit a open loop system and T off to the carbs?
Wont be able to remove it as the carbs wont fill themselves Wink
But im no petrol head so not sure how its normally done, id say either a low pressure pump or an open loop as you said, as you dont want any pressure heading towards them Tongue
[Image: sigi-2.png]
You need a low pressure (3-4psi IIRC) pump for normal carbs, possible stupidly low for bike carbs cos some are gravity fed, not pumped. Look at facet pumps or the rally design copies of the above.
Youll still need a feed and return line and IIRC a pressure regulator too.
From what ive read most people use the fuel pump from the bike the carbs come off of.
