Threads: 3
My year 2000 hdi with 150k is getting about 40 mpg with extremely easy driving. And I really do mean extremely easy - rarely even seeing 2000rpm (still on R plates so I don't really mind cruising at 45-50mph).
Firstly is this bad or is it normal enough? I'm pretty disappoint with those figures. Was expecting more like 50mpg+ with driving this easy.
I have a stage 1 map by Mr whippy and back box replaced with straight pipe. Also serviced 1,000 miles ago.
I'd really like higher MPG so have any of you got any tips?
(I hear that removing the engine increases MPG dramatically)
Threads: 236
36
(11-04-2014, 09:34 AM)Joe306 Wrote: (I hear that removing the engine increases MPG dramatically)
I think it would. Flintstones stylee FTW.
Could your EGR be stuck open?
Threads: 42
28
Drive a little faster, stop labouring the engine, lighter throttle.
Avoid town driving.
Threads: 3
My fuel efficient driving technique has been touching the throttle as lightly as possible and fast gear changes keeping revs very low
Threads: 79
17
Rev it a bit more, the low rpm isnt efficient for accelerating. Also give it some shit once in a while, it clears it out and makes it run better. I try and keep mine just over 2k rpm when cruising. Motorway thats like 65, so not too slow but steady.
There's your problem then. Firm throttle when accelerating, keep revs ABOVE 1500rpm unless cruising.
Threads: 96
7
Car Model/Spec: 306 tractor
(11-04-2014, 10:16 AM)Poodle Wrote: There's your problem then. Firm throttle when accelerating, keep revs ABOVE 1500rpm unless cruising.
and fit some carpet to your front splitter...eh poodle
Hahaha yeah that too!
Pe02 has explained it better than me there. Something else that helps is planning ahead as far as possible - dont watch the car in front, watch the one ten cars ahead. Leave loads of room to the next vehicle, use engine braking as much as possible, dont accelerate until you're clear to continue, etc etc. Hth.
Use the lowest gear possible....thats true so long as the engine is not labouring.
Sounds like you are labouring it
Check your tyre pressures and make sure brakes are free and not binding.
Check your AC is not on and you aint carrying unessersary weight.
Threads: 79
17
DO watch the car in front if you, but watch the cars infront of them aswell. Apply some common sense to that one.
Its all about keeping momentum and being a smooth driver for mpg.
Im a supporter of 2 stroke oil in with my fuel, engine sounds smoother and im fairly certain got more efficient when i started doing it.
Having an engine that can breath easy will help, make sure you air box is cleaned out, maybe a panel filter in there. Regular servicing is key, keep your engine as healthy as possible.
Threads: 93
8
Pretty much all been covered, but more detail is needed as to your driving, it's less about revs, more about load. On a motorway journey I can get over 70MPG, around town I struggle to get to 50MPG, regardless of how I drive. That's also due to the journeys being short, and the engine not getting up to temperature where it is more efficient.
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
11-04-2014, 02:49 PM
(This post was last modified: 11-04-2014, 02:50 PM by Toms306.)
It all makes no difference anyway...
I've been driving mine like an absolute cock trying to clear it out and find some power, done a few backroad blasts mainly in 2nd/3rd for half hour at a time plus a little more than 69mph on the dually...topped up today, done 54mpg just like the last time I topped up!  That's on a 273k mile engine as well....
Yeah, echoing mostly from what others have said... The way I've found to get good efficiency out diesels is to allow them to rev slightly, but don't labour the engine... Sitting with the engine going into antistall to tug you along is still increasing the injection quantity.
Remember *power* is made of two components, RPMs and Torque - if that confuses you, then think about smashing a nail with a small hammer, lots of times a second, or twatting it with a massive sledgehammer once or twice - that's the difference between torque and RPM..
You use fuel to make torque, and technically injecting more frequently (i.e. more RPMs) will use less fuel than injecting lots, less frequently... These engines were designed to be at their most effective at using the least amount of fuel to generate the most power at around 2000rpm... Sitting at 1000rpm asking the engine to tug round the car isn't an efficient way of doing it.
From my experience, let the engine just spin slightly faster, don't press your foot any harder, if anything almost release your foot as revs increase... Don't let the engine "chug" at low RPMs, that's the ECU correcting thinking you're about to stall, uses loads of fuel...
EDIT: Say you use 10 units of fuel at 1200rpm to make 30hp, but you use 4 units of fuel at 2400rpm to make 30hp... You can see that although, yes, you're spinning the engine twice as fast, you're using under half the amount of fuel...
Threads: 96
7
#Endofthread
Threads: 16
19-04-2014, 09:31 AM
(This post was last modified: 19-04-2014, 09:31 AM by SupaStar88.)
40 quid saw me just last 492miles, that's half motorway and half driving the thought the centre of Chesterfield and Sheffield, motorway speed around 70-*10 spending on time traffic ect
Just past*
Using Tapatalk
Threads: 49
Increasing MPG to me = saving money. Find or make your own bio diesel, apply the above techniques and you will save plenty.
Threads: 96
7
The above post, Ruans post before that and you also need to lose weight
Threads: 7
I drove 90 miles the other day in my Diesel 306 Pug and used an 1/8 of a tank. Around 54 mpg @ an average speed of 55mph. Really impressed and much better than the Ford 'Fail' I drove before....
20-04-2014, 04:20 PM
(This post was last modified: 20-04-2014, 04:21 PM by Toms306.)
Lol, don't take any notice of the gauge. I've done 352 miles on a quarter of a tank so far...that's 100ish mpg.
I'm just waiting for the needle to suddenly drop to empty unexpectedly anytime now lol.
Threads: 7
Hahahaha, too right....many a time I have gone out for a long drive, come back with the needle hardly shifting, then out the next day to town and suddenly find it's dropped...
Threads: 3
thanks guys for all the tips. to sum up then drive at around 2000rpm, get to desired speed quickly, don't labour the engine and light throttle when cruising.
cheers folks
That and plan ahead.
Threads: 40
Car Model/Spec: DTURBO
Given 5 thank(s) in 5 post(s)
If you got a stage one map of pro steve or someone it would make a diference. Mine went up a good bit.
Threads: 9
Car Model/Spec: Stage 1 Hdi & 1998 partner van
Given 3 thank(s) in 3 post(s)
Whats the price of the stage 1 map??
Threads: 214
Car Model/Spec: 306 hdi meridian
(21-04-2014, 04:42 PM)Damo Wrote: Whats the price of the stage 1 map??
£100
Threads: 43
Car Model/Spec: 5 door moonstone hdi
You can get them cheaper that 100 mate pm jammapic hes just done me one amd I cant recommend him enough
Threads: 9
Threads: 125
Car Model/Spec: HDi Estate
Ive done 470miles and the gauge is half a tank, thats driving to work and back everyday, 12 miles, and occasionally I take it for a good drive somewhere, 30-50 mile
Threads: 40
Steve used to be 75 for just the file. His maps are very good. Heard jammapic is very good too. Def worth gettin a stage one anyway, transforms the way the car drives.
Threads: 9
Ahh nice one, when im not skint ill get it done
