exhaust regs? need INFO plz.
hello guys im new here just got myself a 1998 d turbo s and and im needing an exhaust and wondering what rules and regs are involved with the decat and having 1 box or something im told. thought id as you people! im after upgrade to standard
can anyone help ?? .
You want a straight through exhaust no decat or anything.
But atm with mot I think you need atleast one box on the system. My hdi had one straight pipe but had a back box with a pipe welded inside.
Ive heard a little bit of a grey area with cats now as well, if the car was made with a cat it has to have a cat.
(30-03-2014, 09:18 PM)kentiiboii Wrote: You want a straight through exhaust no decat or anything.
yeah I thought as much but wasn't 100% so just one box then yeah and the pipe inside the back box is a nice idea thanks
Im not 100% sure but someone will be along to help. You could always use the search or try google.
I know me and a friend are not sure on this decat thing he says pre 96 don't need 1 but after 96 they do? and then I have another friend saying these diesel's need only one box for regs as the decat is useless untill motorway cruising speed I just don't want to buy something that's useless ..
thanks mate ill try that im new here lol and no joy with google cant find ****
As mentioned above...if the car has a cat as standard it will need a cat for mot, however if you've got a friendly mot'er you should be okay. I think its unlikely you will get pulled over for not having one.
(30-03-2014, 09:57 PM)willJspears Wrote: As mentioned above...if the car has a cat as standard it will need a cat for mot, however if you've got a friendly mot'er you should be okay. I think its unlikely you will get pulled over for not having one.
thanks man thing's are becoming clearer now
Wasnt sure if it was set in stone yet. I took mine for mot month before everything changes.
Just keep the can and buy a bolt in decat. That way 20 minute job changing it over.
Or cut cat
open strip out and weld up like me Wink
Using Tapatalk
Welcome
