Doesn't look right. Help?
delete
Are they not normally splined rather than knurled as that one is?
delete
Wack yours out and find out!
Q: why do you need one!?
delete
If it was a tight fit you could bang it in and weld it at the back ti prevent it spinning. Its not ideal though...especially when you forked out money for the correct item.
iirc the lengths are different across the ranges/years aren't they?
(26-03-2014, 11:34 PM)tigerstyle Wrote: iirc the lengths are different across the ranges/years aren't they?
Yes.
I had to change a stub axle on a Phase 1 axle I got in order to use my Phase 2 "big" drum brakes. Phase 1 was too short.
They were both splined however.
Im sure it needs to be splined
delete
knerled or splinde i would say is ok as long as its an interferace fit
but as said check the length as the fit ones to different models
delete
How much was it and where did you get it from?
delete
  Doesn't feel right, almost died declantg 24 12,113 13-05-2013, 02:22 PM
Last Post: puglove
