12-03-2014, 11:03 PM
Hi my turbo seems to have started a loud whistle can anyone identify why it's started this
Loud turbo whistle
12-03-2014, 11:06 PM
Has the cat pipe split? Boost pipe split/fallen off?
12-03-2014, 11:09 PM
13-03-2014, 06:35 AM
Did it start when you decatted it? If so that's fairly normal, removing the cat means the sound resonates up and down the exhaust more.
13-03-2014, 01:40 PM
(13-03-2014, 06:35 AM)Poodle Wrote: Did it start when you decatted it? If so that's fairly normal, removing the cat means the sound resonates up and down the exhaust more. The car was decatted when I got it it just sound like the turbo had got louder and when I let off th revs it's like a dump valve sound
13-03-2014, 02:16 PM
Ah ok, that sounds more like a boost leak. Does it have a front mount intercooler fitted or is it standrd?
13-03-2014, 04:49 PM
13-03-2014, 10:07 PM
In which case it'll probably be a leak around the short silicone between the turbo and the main plastic boost pipe, can see it through the drivers arch if you take the liner out.
13-03-2014, 10:43 PM
14-03-2014, 05:26 PM
Had one a couple of weeks ago with exactly what poodle said, between the turbo outlet and the bottom pipe.
14-03-2014, 06:48 PM
Loud Tapping On Start | td163 | 15 | 4,418 |
07-12-2015, 07:14 AM Last Post: THE_Liam |
Whistle sounding like blow off valve | MY95 | 9 | 1,956 |
13-05-2015, 07:49 AM Last Post: MY95 |
Turbo now really loud | LewisG | 2 | 1,390 |
05-10-2014, 04:28 PM Last Post: LewisG |
