Earth strap
Earth strap
Hi,
I have a year 2000 306 estate 1.6 petrol
I am looking for an earth strap as mine has corroded a bit
Thanks,
Mtbucket.
(06-03-2014, 09:12 PM)mtbucket Wrote: Hi,
Thanks,
Mtbucket.
Id make one bud. I presume your talking about the Battery Negative Lead to the Gearbox?. I Gutted the old battery leads off an Escort van at my local scrappy (which have vertical tightening 10mm nutts) and crimped/soldered new tags on. Works great on mine :-)
If its not what Phil said then I am lost as to what an earth strap is!
Thanks,
Mtbucket.
You will find they are all corroded now. A new one is about £30 from pug.
Which 'earth strap' do you want? I have one from the Battery neg to earth if that's the bit.
(07-03-2014, 09:39 AM)Alex Wrote: Which 'earth strap' do you want? I have one from the Battery neg to earth if that's the bit.
Hi,
This is the one that comes from the battery area and then splits into 2 down near the gearbox
Thanks.
I may be able to help. Will supply a photo of the item I have.
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
(07-03-2014, 11:21 PM)Dangti6 Wrote: I may be able to help. Will supply a photo of the item I have.
Thanks very much, appreciate it if you could.
  Steering Wheel, Clock Spring, Wiper/Indicator Stalk and Check Strap Kezzieboy 7 2,770 20-02-2016, 01:21 PM
Last Post: powerandtorque
Video Wanted: Door Check Strap jonas306 5 1,586 07-02-2015, 09:43 PM
Last Post: Mattcheese31
  Wanted: Drivers side door strap devils_fuel 2 1,312 27-04-2013, 11:22 PM
Last Post: devils_fuel
