Relay
File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Relay
What does the relay missing there?
[Image: u2azuguj.jpg]
My blower heater dont work, its about the missing relay?
[Image: sign.png]
↑ Project ↑
Heater blower relay is green mate. Is it a 3 door or 5 door?
If it's a 3 door it could be for when they use 5 door rear windows (as both 3 and 5 door carry same loom) not sure though
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
mine is a 5 door.
i dont have any green relay on the car :/
[Image: sign.png]
↑ Project ↑
If the heater blower isn't working i'd say do the usual and check the fuse for the circuit then see if you have motor going to the motor...
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
The fuse is ok. The motor i've tested and is ok too.
What you mean abou "motor going to the motor"?
Thanks! Smile
[Image: sign.png]
↑ Project ↑
(25-02-2014, 01:57 PM)Seid Wrote: The fuse is ok. The motor i've tested and is ok too.
Thanks! Smile
I meant power going to the motor haha! Was very tired when i wrote that! Haha
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Yes the power goes to the motor.
Btw, after all i have the green relay.
[Image: sign.png]
↑ Project ↑
