KWP2000+ Problem
When running Windows Mode on my uncles Macbook no kik can be found when running the software after clicking on the ECU and clicking launch, can anyone help?
Sounds like the drivers aren't installed properly, also you've gotta click read within 5 seconds of the ignition being on
(09-02-2014, 09:42 AM)Midnightclub Wrote: Sounds like the drivers aren't installed properly, also you've gotta click read within 5 seconds of the ignition being on
Tried the 2nd part but not sure how to check whether all the drivers are installed or not
Did you install them from the folder? called like 'win 2k_xp_vista_ drivers' or something similar..
If not or you don't have them, download from this thread: http://306oc.co.uk/forum/thread-14969.ht...0+problems
(09-02-2014, 12:40 PM)Midnightclub Wrote: Did you install them from the folder? called like 'win 2k_xp_vista_ drivers' or something similar..
Dont think I did, didnt know you had to, went on that folder and all the icons when clicked on asked what program to run them on
Thanks!
Just quickly... I really don't mean to sound like an arse hole here...
Make sure you ACTUALLY know what you're doing before playing about with remapping your car, not knowing exactly what you're doing and accidentally using wrong drivers/the wrong OS/wierd other things can cause you to brick the ECU... I've seen it before and I can guarantee I'll see it again...
Just make sure you're 100% happy with what you're doing before hitting read/write... I've seen cars get bricked by simply pressing read before now...
Play safe Smile
(09-02-2014, 04:09 PM)Ruan Wrote: Just quickly... I really don't mean to sound like an arse hole here...
Play safe Smile
Thanks for the info, i have a good idea on what to do but not 100%
Just found the guide from HDI-Tuning, the 'Found New Hardware Wizard' boxes didn't come up when I plugged in the device to my laptop and the cars ECU, im a bit confused to be honest
Also realised the main file/application for the XP Drivers didn't come with the software after downloading it from the thread Midnightclub shared
  kwp2000+? the milkman 16 8,104 07-02-2013, 08:42 PM
Last Post: the milkman
