01-02-2014, 12:43 PM
On euro car parts there are several pads available which all appear different to look at. I have a 2000 V reg HDI. Do I require pads without a wear sensor for the Lucas caliper?
HDI front brake pads
You should need the ones with the sensor but you will need to cut the cables off when fitting.
These are the ones you should need. http://www.eurocarparts.com/ecp/c/Peugeo...72d&000036
01-02-2014, 02:37 PM
I don't think I have wear sensors, but is it a Lucas caliper on my HDI?
01-02-2014, 02:59 PM
They're Lucas on mine to but it takes the pads that have the sensors you just have to cut the wires off as there are no plugs for the on the car.
| New Disks and Pads - Front & Rear Recommendations | MisterGTR | 6 | 3,807 |
10-09-2016, 08:15 AM Last Post: cully |
| Best brake fluid and pads? | JTaylor2005 | 19 | 10,628 |
19-08-2016, 08:09 PM Last Post: Pgtips |
| Disconnecting rear brake lines at the front | Iaitoo | 21 | 10,271 |
04-06-2016, 08:22 AM Last Post: pug306driver |
