306 S16: Depression and vacuum gauge, Oil and oil pressure gauge
hello guys ...
I thought what would be the more appropriate section to write this post ... I have not found one so I hope this is the right compromise.
I need to install in the din of the radio 3 instruments:
- Oil pressure gauge
- Oil temperature
- vacuum gauge
As for the oil I think I fit a sandwich between the engine block and oil flter, I have already one with a bout of pressure and temperature.
What do you say? okay as a solution or should I take other roads?
At what point do I get the wire in the car?
As for the vacuum gauge ....
Where do I pass the tube that should be the instrument?
The connection I would do it in T vacuum tube that is divided between fuel pressure regulator and controller. Right?
What values should I have vacuum?
Thanks...
Yes a sandwhich plate between the block and filter is the correct way to do it.
The wires can be passed through into the cabin via a grommit in the bulkhead, if your from another country that would mean your steering wheel is on the other side so grommits might be in different places, so i cant help much there.
Could you not just drill and tap a nipple on the manifold to measure vacuum? Or is it the vacuum of something else you want to measure?
(29-01-2014, 10:13 AM)Tom Wrote: Yes a sandwhich plate between the block and filter is the correct way to do it.
ok thanks. I bought this:
Oil Adapter / Sandwich Plate + Oil Cooler AN10 Connections
description:This adapter plate can be used to install oil temperature and oil pressure gauges, as well as turbo oil lines. Will fit most cars, as we include 2 different installation bolts: M20x15 and 3/4x16 thread.
Color: We send blue or silver, it depends on our current stock.
(29-01-2014, 10:13 AM)Tom Wrote: The wires can be passed through into the cabin via a grommit in the bulkhead, if your from another country that would mean your steering wheel is on the other side so grommits might be in different places, so i cant help much there.
You can also put a picture? thanks
You most a picture or 2 of your bulkhead and i'll point them out.
I would like to explain exactly what I did but my English often do not understand ...
therefore, I put the photos that do not need explanation
[Image: 20140201_163146.jpg]
[Image: 20140201_163414.jpg]
the solutions used
[Image: 20140131_170541.jpg]
[Image: 20140131_170929.jpg]
[Image: 20140131_171943.jpg]
I have some questions to ask you about other tools to install ...
Water temperature gauge ...
where is best to put it?
I thought I'd put it here:
[Image: 100_5630.JPG]
is that correct?
Radiator top hose is the normal spot for those adapters, should get a god flow that way, I'm not sure of that exact pipe on the XU Petrol.
  Gauge problem Nathan1305 4 3,088 14-09-2015, 10:22 AM
Last Post: Nathan1305
