24-01-2014, 11:35 PM
Posted this up on the 206 forum but they dont seem to grasp the issue over there
Having a problem with the mrs 1.4 petrol and wanted a bit of advice
About a week ago the downpipe cracked through where it meets the manifold so before the lambda sensor and fell off, engine management light came on and the car cut out. Had it towed home and got the pipe welded back up off the car put it all back together but now it won't start
So here's the question, why?
Battery is good and was left disconnected for a couple days before I put the pipe back on
When you turn the key there's just a click and that's it, had a problem with the starter not long ago so that's probably what this is. (Worth noting the engine management light wont go off)
Tried to bump start it but as soon as it turns over and starts to go it cuts out again and the management light is staying on
Any help is appreciated especially regarding if there's a way to reset the management without any diagnostic equipment the battery was disconnected for a few days before I refitted the pipe and I was hoping this might of cleared it
