Anyone got this piece - top strut mount.
i need number 7... i believe it's this part, it's a cup shape spacer.
[Image: 163755_10150363359810691_749385690_16929...2843_n.jpg]
basically, when i bought a new top strut mount kit - i fitted it all in the correct order, and noticed that #6 wasn't included. by this point i had chucked out the standard mount and now getting a squeak from the strut side without this cup. it persisted aswell when i tried it on the opposite side of the car.
any help would be awesome - or if anyone goes near a scrappy and could grab one, would be appreciated.
I might be going to one tomorrow. How do I get it out, as I dont normally take tools, just a screw driver lol.
Pompey306mark Wrote:I might be going to one tomorrow. How do I get it out, as I dont normally take tools, just a screw driver lol.
Need spring compressors as its under the top nut
This in peugeot is cheap.
~£7
[Image: sign.png]
↑ Project ↑
ermm... not necessarily, its under the top nut, if there's enough weight between the bottom of the strut and the top, you can unbolt and leave it be - scrapyard - not your problem... :|
What size spanner and I will have a look. It's cheap at the scrappy too... Free.
ginge191 Wrote:ermm... not necessarily, its under the top nut, if there's enough weight between the bottom of the strut and the top, you can unbolt and leave it be - scrapyard - not your problem... :|
Well thats fine if you can have that on your conscience, but I couldnt
Do not take it off without spring compressors unless you want a spring embedded deep in you!
They are less than 3.00 each from pug. I know this because I've got new shiny gold ones on mine.
NiallHarper Wrote:Do not take it off without spring compressors unless you want a spring embedded deep in you!
got part number mate, that would be useful Smile
How can you have the service box image and not know the part no.? -.-
30 seconds of work tells me it's 5077 33 bell End!
  FRONT STRUT TOP MOUNT BEARING procta 1 3,055 27-02-2016, 07:15 PM
Last Post: welshpug
