Bolt search
Bolt search
I'm trying to find in the UK 2 bolts M10 x 1.25 bolt with 16mm thread length and 8.8 grade. The length can be longer and cut down on the 16mm.
Have you tried a local fastener supplier? They'll likely have them in stock.
Failing that, here's some M10 x 1.25 x 20mm setscrews at 50p each:
http://www.margnor-online.co.uk/bolts/8-...ne?cat=233
And some M10 x 1.25 x 25mm setscrews at 64p each:
http://www.hobbfast.co.uk/prod.php?subca...c_Fine_Set
No experience of either company and no idea on shipping costs. I suspect it might end up cheaper just going to Peugeot if you can't buy them from a local supplier.
I'm guessing this is for a stud and nut conversion? You can buy pre cut bolts off ebay Smile
Cancel that, just seen the 16mm thread length lol
It'll be for using Berlingo/Partner P-bushes in place of the 306/Xsara ones which use an M8.
(wheel bolts / studs on Peugeot's are M12 x 1.25 btw)
(16-01-2014, 06:19 PM)powerandtorque Wrote: It'll be for using Berlingo/Partner P-bushes in place of the 306/Xsara ones which use an M8.
There was a thread somewhere of how to upgrade your p-bushes to berlingo ones and how they got around the bolt issue, I'm currently trying to find it lol
[Image: siggy1.jpg]
Local fastening shop had mine, over the counter, cut them down from 20mm ones, cost pence.
So what exact size bolt do I need to buy, sorry being lazy Smile
[Image: siggy1.jpg]
