Head gasket prices
Head gasket prices
Hi guys need the head gasket doing on the pug unfortunately. How much would it cost in total to sort it. Anyone fancy doing this for me?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
A garage could charge upwards of £350 because any good garage will probably charge for;
Oil 5lt £30
Head gasket reseal kit £80
Head bolts £20
Antifreeze coolant £10
New oil filter £10
Head skim £40
Labour £140
Possible new cambelt and/or tensioner -£100
If you do it yourself it will be alot cheaper because alot of those things won't need to be done but a garage would more than likely do them as a matter of procedure on a head gasket change.
I change my gaskets for £20 (just the gasket) and reuse everything else but a garage wouldn't ever dream of that if they didn't want customers coming back with dodgy work I just take my chances on the XUD because labour is free Smile
If your oil is clean still and your coolant isn't bad then you could get away with a skim, gasket change and bolt renewal and be good to go as long as your fluids haven't mixed.
Whatsapp me lad
Team Doesn't own a 306
Ok mate
Ph3 perv cab heaven
Black ph1 XUD died
  Possible head gasket issues? forbeslongden 3 4,656 16-01-2020, 09:39 PM
Last Post: Mighty306
  Head gasket (again!) Pughawk 1 3,163 08-11-2019, 08:59 AM
  Head gasket and Engine rebuilds. weka 2 4,436 15-07-2019, 08:46 AM
Last Post: weka
