Threads: 24
Car Model/Spec: 306 hdi stage 2
Alright lads I'm after a uprated clutch to put in my 306 hdi as I'll be going stage 2 in the next couple of weeks and mine has started sliping so time has come also after intercooler pipes anythink cash waiting cheers
Threads: 17
4
Car Model/Spec: 2000 HDi Wagon
I got a universal kit off ebay, top and bottom pipes off poodle (check the for sale section they're always there) as for the cooler itself, universal ones, jag x type ones etc.
Clutch im not so sure about but personal preference is always organic ones. Paddle clutches are on / off and take some getting used to. Im sure someone will come along with advice and a link or two for ya.
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Very rare to find one second hand. OEM replacements should hold fine on a limited torque map, CG offer and uprated option but say it wont hold any more than an OEM unless you change the pressure plate. CG also have very mixed reviews. Helix rate theirs to 310 ft lbs but its £450.
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Or you can go down the Sachs paddle plate with valeo pressure plate, that set up will hold full toque fine so I believe. Also the helix set up is very heavy pedal feel so it kills the clutch cable regularly.
Threads: 24
Ok and the valio and Sachs will hold well hopefully as it'll be pushing close to 350 ftlbs of torque wich is a heck of a lot with about 180 ish bhp hopefully
Threads: 61
4
Car Model/Spec: 306 HDI
Chris where do/can you get the sachs plate from as I looked like mad, even rang ECP who said they can't get it anywhere
Threads: 266
18
Car Model/Spec: 205 DTurbo
Or swap it to XUD clutch mechanism and go VALEO/LUK or CG.
Threads: 61
4
Whos took the xud setup past 300lbft?
Threads: 266
18
(02-01-2014, 10:07 PM)mcglynn Wrote: Whos took the xud setup past 300lbft?
Who's took a HDi past 300lbft and recorded it? One person..
http://306oc.co.uk/forum/thread-15619.html
XUD setup should be fineee!
He's only going for a boggo-standard stage 2!
Threads: 343
15
(02-01-2014, 09:53 PM)mcglynn Wrote: Chris where do/can you get the sachs plate from as I looked like mad, even rang ECP who said they can't get it anywhere
When I spoke to my ecp they ordered it for me, but I canceled the order, other than that ask Aaron with the moonstone blue hdi he running that set up not sure we're he got it from tho.
Threads: 61
4
Been more than one in that territory id assume. Without proof ofc but it wasnt a dig if youd took it that way..
Just asking, but now that jp has done it/recorded it then there's gonna be a few more soon to follow I would assume due to knowing the spec and seeing its relatively easy to achieve.
Threads: 266
18
02-01-2014, 10:15 PM
(This post was last modified: 02-01-2014, 10:15 PM by silverzx.)
(02-01-2014, 10:12 PM)mcglynn Wrote: Been more than one in that territory id assume. Without proof ofc but it wasnt a dig if youd took it that way..
Oh yeah of course! 100% sure Brynwlogg/Chris was past 300 easily but the monkey never RR'd it before it went boom and that was ageeeees ago!
Sorry, it's my time of the month!
Also, it's all down to mapping end of the day, whether you have same mods or not makes no odds on these!
Threads: 61
4
02-01-2014, 10:18 PM
(This post was last modified: 02-01-2014, 10:19 PM by mcglynn.)
True true and him doing his own meant he got what he wanted.
Guess who I went to for mapping for that exact reason...
Said hes happy to push mine but not to accept liability which is the downfall of some other mappers.
They're mapping for the masses and keep it within safe tolerances, which is great until people want more.
Threads: 266
18
(02-01-2014, 10:18 PM)mcglynn Wrote: True true and him doing his own meant he got what he wanted.
Hah fair play. Push for more! Swear he went for reliability!
Threads: 61
4
Heh reliability!
Yeah im on a budget atm as insurance/tax are due in a few days but I plan to get the clutch out of the way soon hence my interest in this thread.
Going to go with the cg setup I think as if a sachs berlingo oem jobby can hold 270 then im sure the cg is up to 300+
Expensive though, but getting gti6 bits in northern ireland seems a pain I never see any full cars on gumtree nevermind one breaking for parts.
Threads: 79
17
ECP couldnt get me anything more than a standard clutch kit. That was going up through management etc aswell. CG is direct and helix is from mardi gras motorsport. Helix are now not as heavy as their reputation would have you believe. Sean has never broken a clutch cable and after talking to various people its really not that bad. Ill be ordering mine after the weekend and im hoping it will all be in by the end of the month.
