lock barrels
lock barrels
looking for some help please on my car the ignition has been changed as original key was snapped however the door barrels haven't so i cant lock the car i am looking to buy some today is there any difference in the barrels from central locking to manual and the best place to buy them
thanks
Your ph3 will have central locking as standard
yes it has i need to get new barrels so just wondering if i need to get a specific barrel
Ah I see.
just any lock set from another ph3.
no, they're all the same, and VERY easy to swap, all you need is a 4" long wood or chipboard screw, around an 8, it''ll take a few seconds each side to swap them.
the beaters (the plastic lever) is specific to each side from memory, so make sure you pop it in the right side.
ok ill get them ordered today just wondering how to get them out ill have a scan around onthe internet see if i can find a tutorial thanks Big Grin
open door, remove rubber bung in the dor end, wind screw in, pull on screw.
pull loose lock barrel from door, fit new one, push clip back on, replace rubber bung.
