Car Cutting Out
Car Cutting Out
Wondered if anyone could help me with this.
Got the car out the garage yesterday and left it running to warm up, after about 5 minutes it started idling between 500 and 1000 revs jumping up and down trying to keep itself running eventually sorted itself out
today i went out drove about 5 miles come to a junction engaged the clutch and the car cut out started straight up again however keeps doing it.
any help?
Lambda, TPS?
What engine?
sorry its the 1.8 xs
Idle valve.
Remove, clean, replace
Or fit a replacement
is it easy to get to on these?
I believe so
cheers
Yeah will be on/around the.throttle body
[Image: av5ym8.jpg]
Yep ICV. Can clean them but generally it doesn't last long. Once they are shot, that it and unfortunately, the pattern ones are not much better. A Genuine one is about £80 but its honestly a false economy buying the cheaper copies as they won't last long at all!
think ill just cope until february then back to a diesel i think Smile
mines started doing this...only picked it up a few days ago, will have a look at cleaning icv tomorrow, thought it might have something to do with fitting my bmc.
Icv I reckon. A friend of mine had a similar problem and it was actually the power steering sensor.
[Image: Cn91r40h.jpg]
