Alright guys my hdi just died there and won't go again. I changed the fuel filter a month or two ago and found metal filings so I assume this is the best place to start lol.
Any links?
Any links?
![[Image: 20gh7o0.jpg]](http://i41.tinypic.com/20gh7o0.jpg)
how to remove LP pump?
Any links? ![]()
21-12-2013, 04:26 PM
Realistically running up to christmas ECP could be best to get your car back running
21-12-2013, 05:21 PM
Off topic but if.turns out to be Hp pump.i have one for sale cheap
Keep it in mind ![]() Good luck ![]()
21-12-2013, 05:24 PM
Haha cheers. Is there anything else simple to check? It's never cut out before...
21-12-2013, 07:37 PM
Just been back at the car, definately no noise from it priming with the ignition. How do I check if it's getting power?
21-12-2013, 11:32 PM
Multi meter
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
22-12-2013, 06:08 AM
there are 4 wires
2 for level sensor 2 for fuel pump remove the plug look at the pump connection block you should see P+ and P- in the they are the connections for the pump
Okay so I read 11.87 volts across the two thicker wires and 3.95 volts across the two thinner ones
Guessing this is fine and means my pump is fecked ![]()
23-12-2013, 05:55 PM
Alright guys I've sourced a 2nd hand pump just need to know how to remove the screw lid holding it down...is there a special tool ?
23-12-2013, 06:07 PM
Hammer and a big screwdriver. Carefully.
23-12-2013, 06:09 PM
No noises and voltage at the plug is a totally dead LP pump. Hammer and flat head screwdriver, the normal way around, will have the ring off. Ensure you feet it back on carefully and then drive it home the same way else it won't seal properly.
Be careful to of course put the tank seal back on your replacement pump.
HDi Owner for 200k/9 years
23-12-2013, 06:38 PM
Thanks for the tips guys attempting this tonight after work in the rain haha
23-12-2013, 06:42 PM
You can do it in the car though so keeps ya dry!
23-12-2013, 07:57 PM
Lid came off in about 10 seconds, go to fit new pump to find it's the wrong one. Scrappies are useless
23-12-2013, 07:59 PM
did you remove it from a HDi?
I was under impression there was only one type in the 306 hdi Wishes for more power...
23-12-2013, 08:06 PM
It was already out of the car and it was my dad collected it and he's clueless so he just took their word. Suspect it's from a 307 or something
23-12-2013, 08:45 PM
You might be able to take it apart and swap the actual pump? It's easy to disassemble.
