Front Fog Lights
07-12-2013, 10:50 AM
Check the plug that go's to the back of the light as the wires brake inside the casing. I had this with mine so cut the block off. What would be handy tho is having a current reader.
07-12-2013, 11:32 AM
That's one thing I don't have, I got a tonge I could use to see if it's a shocking thing to do? Lol, The car will be at mine tomorrow (Darlaston, not far from you) if you wanna come give it a little look over mate?
07-12-2013, 11:41 AM
07-12-2013, 10:11 PM
I had the same problem but mine was a dodgy relay in the fuse box so I would check that before cutting the block off
01-06-2014, 10:23 AM
Did you ever get this sorted ? I've got a 99 Meridian and neither of my front fog lights work either - despite the light in the dash working.
I've checked the fuse which is fine, but where would I look for the relay if there is one ? (01-06-2014, 10:23 AM)DavidA Wrote: Did you ever get this sorted ? I've got a 99 Meridian and neither of my front fog lights work either - despite the light in the dash working. Like the guy above you said, change the relay, that's what I'm gonna do and hope it works, I think there's also a passenger fuse box as well, not sure, but all the relays on this 306 Phase 2 are getting replaced with new one's pretty soon, the light on the dashboard works on this one as well! (07-12-2013, 10:11 PM)nttrucker Wrote: I had the same problem but mine was a dodgy relay in the fuse box so I would check that before cutting the block off Where's the relay located mate? |
Instrument lights, dash lights not working | boggs | 3 | 2,761 |
26-01-2016, 09:34 PM Last Post: DeeTurbo |
Odometer lights and clock lights inop | bashbarnard | 3 | 2,426 |
23-07-2014, 08:43 PM Last Post: DarkInferno |
N/S Brake lights/Side Lights not working | Grant | 10 | 3,540 |
18-11-2013, 08:02 PM Last Post: Grant |
