they are crap...
look around for the threads on the later berlingo replacement p bushes...100times better
cut it off...wack new one on. simples
Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
Cheers cully, does look a lot more better quality then the ones I found.
I may just replace the unit then stick the new ball joint on the other side, just funding this close to xmas =\
Threads: 61
Car Model/Spec: 306 HDI
i literally fitted these the other day, the problem i had was the wishbone nut was turning and so had to weld it to the subframe. Pain in the ass!
i'd recommend a pair of g clamps to pull the p bush down and remember if your getting the partner/berlingo ones you will need some m10 x 1.25 bolts to bolt it to the subframe instead of the m8 bolt with the originals. Made a mighty difference to the handling of mine as the car was slapping about all over the place on the old bushes
Threads: 87
48
if you haven't done one before i'd just buy the wishbone with bushes already fitted, i found it a ball ache changing the P bush to be honest.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
I wouldnt recomend buying the pre built wish bones fron ebay. The bushes are shit. You will only end up replacing the p bushes againg within the next 6 months. Its piss easy to channge the p bushes.
As piggy says. Pull the rubber bit off. Slit the sleeve thats left, tap it off with a hammer and punch. Hit new one on with hammer & wood . Done.
Id also go for those belingo ones that cully linked. Iv got them on two of our 306s now . And if you ask for for trade cash discount at ECP they are £13.80 +vat each
