13-05-2013, 12:57 PM
Using Peugeot Planet
This is my first time on this forum and I am very impressed on your rundown on the Peugeot Planet and key registering.
You never got back to who the PP clone manufacturer is or any info at all about how to buy one. I live in Australia and four cars. We have a Peugeot 2008 407, 2010 207, 2004 206 GTi 180, a Citroen 2006 C3, and a Suzuki 2010 Swift Ralley. I am seriously considering buying a PP especially as the quantity of PSA cars is growing as well as the age. Too happy with them to get rid of. I have known for some time that a lot of unnecessary maintenance work and replacement parts can be avoided when codes can be accessed and diagnosed (is the same with aircraft, being my trade). Another thing I am puzzled about is that some people buy the PP and the Lexia 3. Aren't they meant to be the same thing except for the connecting harnesses and logo. Could you fill me in on the above please? Regards from the land up over. Cogs
23-11-2013, 07:56 AM
yes pp2000 is the software and lexia 3 is the hardware used i think!
as for where to buy i bought mine from ebay most on there are sold but are chinese clones which get removed from ebay because of the pirate software the one i bought was a clone and works well on my 306HDi 206 hdi (pre can) and 206 1.1 (can) we own at present
23-11-2013, 12:28 PM
I can highly recommend Jim at Easy Diagnostics for all things Lexia. The hardware he sells is top notch and will work with the latest versions of diagbox, as we know ebay clones can be hit and miss. He's also very helpful and will even do remote installation and troubleshooting I believe. He gives a club discount over on French Car Forum, it might be worth asking about one for here?
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04 '05 RenaultSport 182 Cup
26-11-2013, 08:37 AM
(13-04-2012, 08:00 PM)cully Wrote: yes the build code is a roling date code! and build factory code Hi I am new to this forum. I am trying to obtain the DAM for my Peugeot 306 and using the Excel spreadsheet. I got the code from the door sticker and it is as follows: 9631383480 I am not sure which numbers to use to decode the date of manufacture though. Can anyone assist. Chassis is: VF 37AK5A232398998 THANKS
26-11-2013, 11:11 AM
(26-11-2013, 08:37 AM)tropical peugeot Wrote:(13-04-2012, 08:00 PM)cully Wrote: yes the build code is a roling date code! and build factory code the number you quoted is the wrong one your info is Vehicle characteristics Vehicle family 306 (RESTYLING) Build code 7834 Warranty Start Date 01/01/1990 General information PRODUCT TYPE CAR COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT VEHICLE FAMILY 306 (RESTYLING) SILHOUETTE 5 DOOR SALOON TRIM LEVEL SELECTION PACK ENGINE CARBURETTOR TU3-2 TRANSMISSION BVM5 PAINT TYPE NON-METALLIC PAINT INTERIOR TRIM TYPE NAPOLI VELVET "EH" UPHOLSTERY COLOUR "FY" GEARBOX (CHARACTERISTICS) UP-RATED BVM/MA (A/B) ENGINE (TYPE) TU/TUD OTHER BADGE, " MISC. " WITHOUT FULLER BADGE BADGE XR Vehicle characteristics TRIM LEVEL SELECTION PACK PAINT TYPE NON-METALLIC PAINT INTERIOR TRIM TYPE NAPOLI VELVET "EH" UPHOLSTERY COLOUR "FY" GEARBOX (CHARACTERISTICS) UP-RATED BVM/MA (A/B) STEERING UNVARIABLE POWER STEERING SPEEDOMETER DRIVE TACHO TORQUE 21X18 Fuel supply-Engine ENGINE CARBURETTOR TU3-2 FUEL FILLER CAP FUEL CAP WITHOUT LOCK DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM FUEL PETROL (87/98) EMISSIONS STANDARD (ENGINE) 15-04 DEPOLL (ENGINE) PRE-FILTER ASSEMBLY WITH PRE-FILTER ENGINE (TYPE) TU/TUD CATALYTIC CONVERTER WITHOUT CATALYST OIL COOLER WITHOUT OIL-WATER DISTR CHAMB ENGINE TEMP. NOZZLE ENGINE WATER TEMPERATURE BOX CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT FUEL SUPPLY CUTOFF NO FUEL FEED CUT-OFF POWER VARIATION (ENGINE) STANDARD POWER REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE RHEOSTAT NO RHEOSTAT FAN 1 FAN , 2 RATES FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT Gearbox Transmission TRANSMISSION BVM5 GEARBOX (CHARACTERISTICS) UP-RATED BVM/MA (A/B) FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 13 X 59 SPEEDOMETER DRIVE TACHO TORQUE 21X18 WHEEL STYLE BLACK OPTIMIZED WHEEL CLUTCH CABLE CLUTCH TAKING UP OF PLAY AIR CHAMBER WITHOUT INNER TUBE GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING DIFFERENTIAL (GEARBOX) STD GEARBOX DIFF TYRE (SIZE, TYPE) 185X65X14 H TYRES WHEELS FITTED 5,5" RIM ROAD WHEELS WHEEL (TYPE) STEEL WHEELS GEARBOX TYPE MA Suspension-Steering-Brakes ABS W/O ABS BRAKES REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20 ANTI-THEFT DEVICE STANDARD ANTI-THEFT STEERING UNVARIABLE POWER STEERING FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 18 TRACTION CONTROL WITHOUT ANTISLIPPING SERVICE BRAKE WITH INTEGRATED COMPENSATOR BRAKE TYPE NON-VENTILATED FRONT DISCS/REAR DRUMS SUSPENSION FR/RR HEAVY DUTY SUSPENSION BRAKE ASSOCIATED VARIANT WITHOUT ABS Body fittings TOWBAR WITHOUT TOWBAR HORNS HORN STANDARD AERIAL LONG ROOF AERIAL FUEL FILLER CAP FUEL CAP WITHOUT LOCK WIPER ARM FRONT BLADE WITHOUT DEFLECTOR HOOD WITHOUT HOOD REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS WIDTH = 40 WHEEL EMBELLISHER (STYLE) FUGUE STYLE 5 HOLES 14 INCHES ADDITIONAL SHIELD (UNDER ENGINE) ENGINE UNDERSHELDING HARD TOP WITHOUT HARD-TOP EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER ENGINE BAY SOUNDPROOFING WITHOUT SOUND-PROOFING WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR REAR SCREEN WIPER REAR SCREEN WIPER HEADLAMP WIPER W/O HEADLAMP WIPER FRONT PANEL BLANK BUMPER GRILLE NOT CLOSED BUMPER UPPER PART DYED - LOWER PART BODY COLOUR LUGGAGE RACK WITHOUT ROOF BARS FRONT FOGLAMP NO FRONT FOG LIGHTS SPECIAL HEADLAMP (DOUBLE OPTIC) SINGLE OPTIC LAMPS EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO SPARE WHEEL STEEL WHEEL + STANDARD TYRE EXTERIOR ACCESSORIES UNCOLOURED DOOR HANDLES + DOOR MIRRORS SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER REAR SCREEN WASH REAR SCREEN WASH SUN ROOF FIXED ROOF HOOD COLOUR WITHOUT HOOD REAR WINDOW (TYPE) REAR GLASS HEATED GLASS (APPEARANCE) TINTED REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS Interior fittings INTERIOR TRIM TYPE NAPOLI VELVET "EH" SIDE ARMREST (TYPE) LATERAL ARMREST INJECTED FR/RR ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM REAR HEAD RESTRAINT WITHOUT REAR HEADREST FRONT HEAD RESTRAINT JOINTED FRONT HEADREST REAR SEAT SEPARATE FOLD BACK BENCH SEAT REAR SEAT ARMREST WITHOUT REAR ARMREST LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP LUGGAGE COVER WITH LUGGAGE COVER REAR SEATBELT RR RETRACT BELT+STATIC LAP FRONT SEATBELT INERTIA REEL STRAP LOCK WITHOUT ALARM CLIMATE (AMBIENT TEMP) HOT COUNTRIES SPEED GRADUATIONS GRADUATION KMS/H GRAB HANDLES FR + RR HANDLES WITH HOOKS TACHOMETER REV COUNTER WITH NEEDLE CONSOLE LONG CONSOLE WITH AIR DUCT DRIVING POSITION RIGHT HAND DRIVE LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH DASHBOARD EQUIPMENT THERMOSLEEVED DASHBOARD + METAL PANEL MISC. INT. LAMPS MAP READING LAMP INSTRUMENT PANEL (CHARACTERISTICS) 4 DIALS WITH LUMINOUS NEEDLES TACHOMETER (SIGNAL CONNECTION) REV COUNTER COIL CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING LOUDSPEAKER 4 LD/SP DUALCONE (2/FR DOORS+2 REAR) RADIO CONTROLS WITHOUT REMOTE RADIO CONTROL SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK ROOF CONSOLE LONG ROOF CONSOLE CHOKE CONTROL MANUAL CHOKE FLAP CONTROL EXTERIOR TEMP. INDICATOR WITHOUT EXT TEMP INDICATOR COMPACT DISC WITHOUT COMPACT DISC REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER DRIVER’S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER CLOCK NUMERIC CLOCK COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING OIL GAUGE W/O OIL LEVEL INDICATOR HEATING ELEMENT NON HEATED SEAT FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG PASSENGER AIRBAG NO PASSENGER AIRBAG EQUIPMENT PACK W/O EQUIPMENT PACK COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP HEADLAMP HEIGHT ADJUSTER MANUAL HEADLAMP ADJUSTMENT FRONT SEAT GUARD WITHOUT SEPARATION GRILLE RADIO RECEIVER RADIO EQUIPMENT REFRIGERATION SINGLE AIR CONDITIONING CRUISE CONTROL WITHOUT SPEED CONTROL DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ RHEOSTAT NO RHEOSTAT AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP CARPET COVER W/O CARPETMAT DRIVER AIRBAG NO DRIVERS AIR BAG CARPET DILOURS CARPET F330 WEAR INDICATOR W/O BRAKE WEAR WARNING LIGHT INTERIOR PROTECTION W/O PROTECTING NET SWITCH NO CODED IGNITION COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING TRIM ADAPTATION WITHOUT MOULDING ADAPTATION LOCKING CONTROL SIMPLE CENTRAL LOCKING REAR WINDOW (TYPE) REAR GLASS HEATED REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH STORAGE SPACE LOCKS LOCKING GLOVEBOX FAN 1 FAN , 2 RATES Electrical ALTERNATOR ALTERNATOR 80 AMP HORNS HORN STANDARD BATTERY BATTERY L1 250 STARTER MOTOR STARTER MOTOR CL 2 LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT MISC. INT. LAMPS MAP READING LAMP COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP FRONT FOGLAMP NO FRONT FOG LIGHTS HEADLAMP HEIGHT ADJUSTER MANUAL HEADLAMP ADJUSTMENT SPECIAL HEADLAMP (DOUBLE OPTIC) SINGLE OPTIC LAMPS Component manufacturers BRAKE ASSOCIATED VARIANT WITHOUT ABS INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT Miscellaneous SPECIAL SPECIFICATION STANDARD ATMOSPHERIC CONDITIONS DUSTY ATMOSPHERE DRIVING POSITION RIGHT HAND DRIVE SIDE IMPACTS DOOR WITHOUT REINFORCEMENT SET OF KEYS 1 I/R PLIP KEY + 1 PRINC UNIQ KEY DOOR SEAL WITHOUT SEAL DIRT EXCLUDER SURFACE CONDITIONS UNEVEN TERRAIN EXTERIOR ACCESSORIES UNCOLOURED DOOR HANDLES + DOOR MIRRORS SPEED MONITORING WITHOUT SPEED CHECK SLAVE CONTROL UNIT 30 FUSES BOX EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
27-11-2013, 05:42 AM
Wowwwww....Thanks so much Cully!!
All of this could well have saved me so much hassle in the past when I have been buying spares and stuff in various countries... The build code 7834 allowed me to use the software and determine the year of manufacturer ie. 1998. It matches what I originally thought but was not absolutely certain. I have looked everywhere on my car for this code but cannot find it. Just out of interest can you advise where this code is located. I have a serial number embosed on right side of engine bay. Manufacturer plate in the boot and loading details by front right door. None of my plates or stickers matches the format and content of the samples I see on the web though and none of them have this code? This morning I found another strange code on the manufacturer metal plate right at the bottom----> 64108 but sadly this is yet another one of the many codes I find but no idea what the intent is!! I can send you pics of the plates and stickers I have...my car was built in France and exported to Seychelles (where I live) Again much appreciated.
27-11-2013, 06:26 AM
being a 7 code it it either on a strut top painted numbers or on the bulk head lip near where the heater motor is on a R/hand drive car later cars have the info on stickers on the drivers A or B pillar
27-11-2013, 04:19 PM
I assume if when you try programming a key and it says incorrect code...its because the code on the card is wrong?
Got a HDI here and the key dosnt lock it, put new battery in and still dosnt work, so went in pp2000 and tried programming key using the code on the peugeot key code card which was in the dash tray, but to says its wrong? Must be a random card i guess someones just dumped in the car? | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
27-11-2013, 05:29 PM
(27-11-2013, 04:19 PM)darrenjlobb Wrote: I assume if when you try programming a key and it says incorrect code...its because the code on the card is wrong? If the code is incorrect, it won't even let you to the stage where you program the key. Will just say incorrect code. Your issue sounds like the fob is buggered or the fob is from another car
08-03-2014, 06:04 PM
I take pp wont install on anything other than xp since I see a few people looking for an old xp laptop I have tried installing on my vista laptop and win7 desctop but both crash at the splash screen?
23-03-2014, 01:37 PM
Hi all,
First post here! I recently got the cloned PP interface off Ebay and it is possible to run it on Vista/Win7/8 machine using a virtual XP. I first tried with the Windows 7 version of the virtual environment but got errors, but with a bit of hunting found the solution. Download and install VMware player plus, this is free; http://www.vmware.com/uk/products/player the download link is at the bottom of the page then as per the detailed technical explanation on this post; https://communities.vmware.com/people/jm...og/2012/03 add this monitor_control.enable_rigorous_fpu_save_restore = TRUE to the bottom of the .vmx file (edit using notepad) Hey presto working PP on virtual XP, no need to dual boot or suffer XP as your main OS on your laptop!
01-01-2015, 04:46 PM
There should be a button labelled something like "erase fault codes", can't remember where or what f-key it is.
https://www.youtube.com/watch?v=lRLatH0t8U0
At 0:33 shows the third item on the menu as the option to clear fault codes.
20-07-2015, 06:12 AM
sorry to bring up an old thread. I needed the display reset in my car after having to change the MFD due to fade out. The local Peugeot dealership didn't know how to do this, "I can put a post on the help forum if you like" was their suggestion. I hunted around various forums for advice and found enough information to give me the confidence to go ahead and do it myself.
me has a lexia 3 cable from a french forum-auto forum, price is not cheaper than ebay or others, but with better firmware built, with 3 software: lexia 3, Peugeot Planet v48 and Diagbox v7.57 http://yellowbend.bloggets.net/lexia-3-p...-on-407c5/ There are various videos available on the internet to show how to install and use this software. There were one or two updates to add but these were no problems either. When plugged into the car it was surprisingly easy to navigate through the menus and configure the display to my settings. I now have a fully functional diagnostic kit for all Peugeot and a good few quid still in my pocket. I have no Citroen cars, i am not sure if it works as good as Pug.
21-07-2015, 09:27 AM
best place to get a copy of pp please, I now have an xp laptop.
21-07-2015, 10:59 AM
(21-07-2015, 09:27 AM)pug306driver Wrote: best place to get a copy of pp please, I now have an xp laptop. version PP2000 v23.14 + update v24.99 is available from your local torrent web site currently with 7 seeds ![]() file size is 1Gb currently downloading at 2.1MB/s https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
15-11-2016, 05:45 PM
31-05-2017, 10:54 AM
I've recently bought PP2000 and have followed the guide on how to use it but for some reason it won't read the cars BSI or ECU, it will however read the ABS, airbag and Air Con ecu. I've re ran global testing numerous times and even tried specififically on each ECU but got no where. Could this mean my cars had a new ECU and BSI at some point in its life or is there a fix? Thanks for any help
12-09-2017, 04:01 PM
Any more info on getting dtc's, bar graphs for tps and alike please
![[Image: e0d4ac7c-727f-46a8-ae0c-d4a324a8a667_zpsyn3ibroz.jpg]](http://i889.photobucket.com/albums/ac91/lewisgilliatt/e0d4ac7c-727f-46a8-ae0c-d4a324a8a667_zpsyn3ibroz.jpg)
