24-11-2013, 10:02 PM
Hi I need a turbo but I don't know what turbo I need it's a phs2 1.9 td with the Lucas pump and injectors could any one help?
Turbo identity?
Could be a t2 or gt15 or a k14. Cant usually tell without looking
Or a k03 but there rarer
24-11-2013, 10:28 PM
Im going with K14.
Unless you can see the turbo and describe a bit, your guess is almost as good as anyone elses.
24-11-2013, 10:38 PM
Didn't the ph2 normally come with the T2? A k14 will fit with the mani
24-11-2013, 10:49 PM
You don't need any specific one, any of the range will fit with the correct oil lines and manifolds
Stage 2 XUD Sedan
25-11-2013, 12:11 AM
My ph2 has a Lucas and T2, so thats my bet.
To the OP, your best option is to jack the car up, get underneath it, and either identify it yourself (Darren Lobb's Stage 1 tune video on youtube helped me identify mine), or get some pictures of the turbo and post them on here, and one of us will tell you what you're running.
25-11-2013, 12:27 PM
What reg is it?
If it's a late S or T plate it'll probably have a K03/GT15. If it's P, R or early S it'll have a T2 or a K14. As a general rule, if it's got the bootlid without the black strip at the bottom - it'll have a GT15/K03, if it's got the black strip it'll have a T2/K14 - as said, general rule, I've seen exceptions, but they're rare. Just need to find if it's a T2/K14 or a K03/GT15 if you're replacing it. Just get underneath and have a quick gander and take a photo - someone on here will be able to tell which.
25-11-2013, 07:11 PM
(25-11-2013, 12:27 PM)Ruan Wrote: If it's a late S or T plate it'll probably have a K03/GT15. If it's P, R or early S it'll have a T2 or a K14. Strangely though "guy's" phase 2 R plate is running a K03 - likely to be the general rule of thumb by peugeot, whatever turbo to hand will be bolted on
25-11-2013, 08:09 PM
My s plate ph2 had a k03
