Airbag light!!
Airbag light!!
Exclamation
Just brought my 306 few days ago and an airbag light has lit up on the speedo. Anyone know what this could be??
Normally the pretensioner connections under the seats they can get loose due to stuff been rammed under the seats
as dan said unless you have turned the key to disable the passenger airbag
Thanks guys will have a look at this later on an let you's know how I get on
As said its normally the pretentioner under the seat just push the plugs together
Just fixed it today I had the same problem airbag switch for passenger side was on but the airbag light just stayed on constantly all the time so,
We removed the wires from under the passenger seat and cut all the plugs, Re-soldered them back together, Did the same with the loom under the drivers side seat but that didn't fix it.
FIX:
We took out the central column (The whole thing) and underneath where the front ash tray is there's another loom for the airbags and pretension's there's also an ECU unit for the airbag just above that is the loom, We un-plugged all of them, Plugged em back in and it was gone no more air bag light. Result Smile
Did all of this without removing the battery.
Your Welcome Smile.
(24-02-2014, 07:47 PM)Zeuse47 Wrote: Just fixed it today I had the same problem airbag switch for passenger side was on but the airbag light just stayed on constantly all the time so,
FIX:
Your Welcome Smile.
Er.... Im just going to say that the above isnt the proven method and i wouldnt advise doing it.
