Threads: 177
3
05-11-2013, 06:58 PM
(This post was last modified: 05-11-2013, 06:59 PM by Daniel306.)
Anyone know if the 136hp engine in the 307 uses the same flywheel as the 306 hdi?
Bought a 05 307 Hdi XSI fairly cheep as the clutch is just starting to slip so was planing to remove the dual mass flywheel when the gearbox is off
Threads: 541
124
Different flywheel, clutch, release bearing and box.
They are DMF, different clutch, hydraulic release bearing and an ML series box.
Threads: 177
3
05-11-2013, 07:23 PM
(This post was last modified: 05-11-2013, 07:24 PM by Daniel306.)
looks like i need the £350 kit on ebay? thhink it is ML, its 6 gears
When changing into 4th when accelerating it crunches but when slowing down its fine, sound like a synchro ring? Should i try new oil, replace the box or just the synchro ring?
Threads: 541
124
Try changing the box oil first and see what comes out with it (ie chunks of metal) as £15 is alot better than a new box.
Dont try rebuilding the box, its a mind f*ck and needs a load of special tools.
If your doing the box you might as well swap to a SMF and new clutch but make sure you get the right ML as they have different FDs
Threads: 177
3
Are they much worse than a be3 to rebuild? iv just fitted a full quaife kit to my 205 box
Threads: 541
124
Oh if you've rebuilt a box before then its probably no issues. I opened up a BE3 and thought f*ck rebuilding that (and I've rebuilt engines, turbos, calipers etc)
Threads: 177
3
Did it once today when going into 2nd, and it only dose it when its hot so makes me think the oil needs changed
Threads: 177
3
11-11-2013, 08:14 PM
(This post was last modified: 11-11-2013, 08:14 PM by Daniel306.)
Changed the oil and it was much thicker than the new stuff i put in and it made no diffrence, looks like i need to keep a lookout looking for a new box...
Threads: 6
Car Model/Spec: 308 HDi 110 Expert XUD Td
Does anyone know what gearbox an XUD engined Expert van uses, it is a cable clutch.
