03-11-2013, 01:01 PM
Whining noise?
03-11-2013, 02:20 PM
Belt covers?
Anything rubbing should be fairly evident on inspection.
03-11-2013, 08:09 PM
03-11-2013, 09:21 PM
Yeah it did. Thats after I changed the water pump cam belt and ideler pulley. Got the bastard in the end. Im not saying that thats your problem but it could be. Make sure you buy the right ac pump if this the problem as I was told all ac pumps are the same. There not. Had to strip both down to make a good one
Ac still dont work but the noise has gone. Or get a shorter belt and do away with the pump altogether and save weight.
03-11-2013, 09:52 PM
(03-11-2013, 09:34 PM)kingy Wrote: Yeah it did. Thats after I changed the water pump cam belt and ideler pulley. Got the bastard in the end. Im not saying that thats your problem but it could be. Make sure you buy the right ac pump if this the problem as I was told all ac pumps are the same. There not. Had to strip both down to make a good one Yep cam belt + water pumps at the top of the list to do. ah right I'll look into that, cheers for your help ![]() |
1.8 whining in 3rd and 4th | PugRory | 4 | 2,432 |
13-01-2014, 09:06 PM Last Post: PugRory |
