Petty in veg
Petty in veg
(26-10-2013, 04:03 PM)Andy annear Wrote: Yeh ? bosch recomended?
Bosch are good so are Beru . .Smile
ok cool, thanks
Check for air ingress into the fuel system as well, is a common problem.
So what's the down sides to putting to much petrol in Veg Oil???
that a diesel engine is not designed to run on petrol!!!
(28-10-2013, 12:05 PM)Piggy Wrote: that a diesel engine is not designed to run on petrol!!!
Is it not? Dam that's were I've been going wong all this time Confused lol
What problems is it gonna cause? What's the max % to use? 10% 20%
Personally don't go over 10%, normally 5% is sufficient.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(28-10-2013, 12:17 PM)Anton Wrote: Personally don't go over 10%, normally 5% is sufficient.
Thanks I'm running it at 10% now so won't go over that, it's only the first start I have issue with looking at haveing a small tank for derv and twin tank it so start on derv and switch to Veg oil, but struggling to find an electronic 3 way valve to switch Fuel, any one no we're I can get one from?
you don't need to do that mate, your problem lies elsewhere . . Smile
yeah thats waaaaaaay too much hassle for really no gains.
just get the mix right/decent oil.
Mine started bang on every morning last year all through that snow, and that was 90% veg and 10% diesel as I had a load of diesel given me in jerrys.
But I had sorted all the little air ingress places and sorted decent plugs n battery. 2/3turns of the engine and away with a little chuckle to itself for 10/15seconds then fine.
I will have to see how it goes when it's colder. Last winter in d turbo I put 13 liters of derv in a full tank of veg and it was ok, but I was having issues a few weeks ago so had to start mixing petrol and it's been ok since. See what it's like when it's colder
Delubrciates the pump bud. Can cause seizures as well.
Should have said I'm adding 200ml of 2 stroke to every tank to
Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning Wink
(31-10-2013, 12:51 PM)THE_Liam Wrote: Just as an FYI for northern folk, it's meant to be dropping to 2-3 degrees Sunday night into Monday morning Wink
I've started parking car on road so if it be's a nob I can bump it lol the joys of veg oil lol
Having tried to bump a car on veg oil, good luck with that Wink
When I had issues before that's what I did bumped first time Smile
