I bought the car 3 years ago as a stop gap car, every mot i have taken it for it has always gone straight through, and last week was the same, so i thought i would treat the car.
It already has a stage one map so yesterday i fitted a K&N panel filter.
And a powerflow exhaust, i bought this a little while ago second hand, but when it came to fit it, it fitted perfectly better than some standard systems i have fitted in the past. It is a de cat no centre box and just the straight through rear box. The tail pipe is a bit big for my liking but as it was second hand beggars can't be choosers, so it will do.
I got a genuine pug fitting kit, with the new nuts, springs,washers, the gasket and 2 new bolts/studs just in case i snapped one but luckily i didn't.
The car does go much better now it revs up a lot more freely and doesn't feel as restricted as it did before with the cat fitted. It is pretty loud, it is ok when your cruising but when you boot it you can certainly hear it !!
I am going out in a bit so will try and get a video of it.
