Semi ecu controlled pumps
What's the differance between these?
What bit is controlled exactly
Team Doesn't own a 306
something to do with advance I think?
Yeah the advance is controlled by the ecu. You can drive without the ecu but it will be horrendous, stuck in full advance. You can still shim the timing piston though
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
Yeah I smashed one of these up, the leverset, lda, gov cradle, plunger and associated gubbins can all be used, just the whole thing itself that is useless due to the stupid mechanism.
  Lucas Pump: mechanical or semi-ecu controlled? andy_diesel 3 3,909 23-11-2016, 05:00 AM
Last Post: Dave
  Semi ecu pump to standard advice bashbarnard 7 4,002 17-12-2015, 06:45 AM
Last Post: bashbarnard
  FAI Water Pumps RAW 12 10,013 18-02-2015, 12:13 AM
Last Post: vinny
