ECU location,
ECU location,
anyone know the exact location of the ecu thanks dudes, replacing the central locking from a scrap moter i got, i git x reg 306 meridian thanks,..
so do you need location of the ecu thats runs engine or central locking!?
(21-10-2013, 07:56 PM)Piggy Wrote: so do you need location of the ecu thats runs engine or central locking!?
[/quo ECU thanks i know where the central locking is under back seat cheers ...
[quote='matthensley' pid='345350' dateline='1382394724']
[quote='Piggy' pid='345225' dateline='1382385381']
chip in key not working so replacing ecu barrel and chip thing by barrel and the main computer sholud do it do you think.?
Not being funny, but open the bonnet and it's pretty obvious!!
Normally a silver unit, roughly 4x5x1inches with a load of wires coming out the top/side.
Lol, as above, it's behind the battery, in its own separate compartment of the battery box on the 1.4.
You'll also need to change the BSI (immobiliser box) which is at the bottom of the centre dash, roughly behind the cig lighter, in that area. You don't need to change the pickup around the barrel as it's just a 'reader' rather than containing a code. And you also don't need to change the key barrel, just swap your key blade onto the replacement key fob.
For all that hassle it might just be easier to get it recoded.
If he's replacing the transponder chip etc, he most probably means the BSI guys. Which is below the temperature/clock unit in the dash Smile
thanks everyone, its 120 quid for key to be done at dealers here so not cheep, will try an sort it my self, i'm pimping my ride any way, thanks again.....
I have unlocked ECU if interested out of 306 LX 1.6 bypasses the immobiliser
Big Grin 306 Cabriolet Alarm Unit location Oldyroady 5 5,572 18-03-2019, 08:18 PM
Last Post: Oldyroady
Question Best Position/Location for Battery -ER- 2 2,943 11-03-2016, 07:27 AM
Last Post: Frosty
  306 gti6 transponder location Steve 306 gti6 1 2,477 10-01-2016, 12:27 AM
Last Post: connorcarp72
