Power steering
Power steering
How much play are we talking?
Our of interest, why don't you get the play with the pas running?
JP
JP
The "play" is the gap that the power steering system needs to tell where to pump the fluid. So you turn the wheel right and opens up a little gap for the fluid to flow through, turn the wheel left and the fluid will run through the other little gap and pump the fluid the opposite way
Ok, so are you saying you get the same "Play" even with the pas enabled and running? Always wondered how it works!
JP
You dont really get any "play" as its taken up by the fluid
As connor says, whilst you do get slightly vague steering from PAS, the 'play' isn't there because the torsion bar turns the shuttle and the hydraulic fluid starts to move the ram.
Are we talking a lot, or a little? I suppose I can test by, as above, taking the belt offhand trying it thus...
JP
~5 degrees or so perhaps, never really measured it, you can feel it though.
Hmmm... So you don't get any "play" as such with the pas up and running? Maybe that's what I should do then, just relocate it out of the way...
JP
JP
I'll explain it better when I take some pictures, but basically with PAS on the steering usually 'floats' between the two stops, the only thing giving feedback for small movements is the little dinky torsion bar in the middle, which is why PAS setups filter out a little of the steering feedback -there's effectively a flexy bit between the rack and the wheel.
For one with no PAS, because the ram doesn't move the shuttle, you have a little bit where you have the spring of the torsion bar only, then the stop where it's basically direct through. A normal non-PAS rack just goes straight through.
Ah ok. Get some pics, it'll make sense then! So you think no pas is the way to go then? But obviously modify the rack to suit....?
I can't even remember what a non pas rack feels like!
JP
Just weld it up, that's all I've done today on mine. I'll post the pictures up later.
Before you welded it, was there loads of play or something?
JP
  Power Steering Pump, All The Same? bigcheez2k3 14 10,871 20-11-2020, 11:28 AM
Last Post: vento85
  Power steering rack.....replacement options Jellomanpie 9 8,823 30-04-2020, 05:54 PM
Last Post: Mighty306
  Power Sterering Ram/ Steering damper pugfrank 6 6,578 08-11-2019, 01:47 PM
Last Post: pugfrank
