(25-09-2013, 07:45 PM)CJ_Derv Wrote: Its not easy tbh I need to redo a few bits as didnt have a geat gun so had to use hairdryer but better with heat gun so can really stretch it
Careful over heating it mate otherwise it seems to just let go and stretch a lot suddenly.
Threads: 124
26
Car Model/Spec: Megane DCiR
I know what u mean pal, I found that out when I did the 306 interior first time round tbh this wrap was too thick its exterior wrap and is harder to manouver so not ideal for out handle shape but will but some better stuff and redo didnt really take that long tbh
Threads: 124
26
28-09-2013, 02:43 PM
(This post was last modified: 28-09-2013, 02:46 PM by CJ_Derv.)
http://youtu.be/KDgpJ0EfSOU
Airbox chop done
Garrett GTA1549LV
Needs a bigger turb
Interesting, didn't know they ran a 1549VL...
Watercooled cartridge!
Get a GTB2056VLK on
Threads: 96
7
Car Model/Spec: 306 tractor
Sorry for not being with the kids, an airbox chop? Is that just shortening the airbox length due to it being way to big when std?
Progressing well mate
Threads: 124
26
Il look into that ruan will that just be a straight swap you think? Would have to get another map done obv but not too clued up on GTA's
Air box mod is basically cutting a square out of the original air feed in corner of box makes a huge difference very noisy not sure if too noisy yet havent decided
amazing what modern designed heads/pistons and injection systems can do with a gt1549!!
Threads: 27
20
Not slating! But that clatter at idle ιs obscene! Quietness down a hell of a lot when reved though! What torque ιs ιt pushing?
Threads: 124
26
28-09-2013, 06:23 PM
(This post was last modified: 29-12-2020, 02:53 PM by CJ_Derv.)
(28-09-2013, 06:13 PM)Jonny b Wrote: Not slating! But that clatter at idle ιs obscene! Quietness down a hell of a lot when reved though! What torque ιs ιt pushing?
It should be around the 350 360 mark pal
Threads: 27
20
Cool!! Do you know what the limit ιs for these engines? You gonna push for more?
Threads: 138
72
Car Model/Spec: Mincebus
The standard air inlet pipe is very restrictive, hence people cut the corner out of the box removing the inlet restriction  generally frees up a few ponies too!
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 96
7
Thanks CJ and Ed, I understand the mod now.
CJ..any better for it?
Threads: 124
26
30-09-2013, 02:16 PM
(This post was last modified: 29-12-2020, 02:54 PM by CJ_Derv.)
(28-09-2013, 06:25 PM)Jonny b Wrote: Cool!! Do you know what the limit ιs for these engines? You gonna push for more?
Il find out I guess no one had gone past 212bhp and 350ft lbs as far as I know
(28-09-2013, 08:21 PM)devils_fuel Wrote: Thanks CJ and Ed, I understand the mod now.
Initially yess improved pickup and feels bit more torquey and loud but then have the issue of throttle sensor more often now so cant get full throttle and its pissin me right off changed fuel filter too and got to clean egr and see if that makes a difference but must be throttle sensor
Threads: 96
7
(30-09-2013, 02:16 PM)CJ_Derv Wrote: Initially yess improved pickup and feels bit more torquey and loud but then have the issue of throttle sensor more often now so cant get full throttle and its pissin me right off changed fuel filter too and got to clean egr and see if that makes a difference but must be throttle sensor
PITA, rip it all out and XUD it
Threads: 138
72
CJ I think there is an issue with some of the sensors working loose on the inlet mani, which may be the cause of your problems... Might be worth looking into x
Threads: 124
26
Could make sense as it doesnt seem to be boosting all the time gona plug it in tomorrow and have a look around pal thanks for help buddy
Can tell when its boosting and not with exhaust tone since dpf removal although launch on insta shows boost
Threads: 124
26
Had a reset on ecu and seems ti be back boosting but not too sure if back to scratch somwthings still holding back think its got to be egr as everything cleared and still lagging
Threads: 142
58
Car Model/Spec: E46 BMW 320d
You seem to be making pretty good progress with this mate, like what you're doing! Still not my cup of tea though, but if you like it, thats what counts. I also echo Darrens comment, at least its a derv!
One other thing, Liam also picked up on it, you need a new sig. So i made you one while i was bored.
Hope you likey!  I won't be offended if you'd rather make your own, and dont use mine. Honest.
(28-09-2013, 06:05 PM)CJ_Derv Wrote: Il look into that ruan will that just be a straight swap you think? Would have to get another map done obv but not too clued up on GTA's
Yeah, you'd need another map done, but in their stock application they make ~220hp - the GTBs are such incredible turbos for their size...
Should be able to see ~280-290hp at a guess, maybe even more - and they spool up stupendously quick!!
Probably the sweetest turbo for a ~2.0 engine if you want outstanding driveability.
Threads: 124
26
Threads: 138
72
Can you not get the get sacked off and mapped out?
Threads: 124
26
(01-10-2013, 03:35 PM)Ruan Wrote: (28-09-2013, 06:05 PM)CJ_Derv Wrote: Il look into that ruan will that just be a straight swap you think? Would have to get another map done obv but not too clued up on GTA's
I thought I mite need a map going to speak to RS Tuning in leeds and weigh up a decent size GTB and then look at getting the injectors refurbed or uprated but the M9R are renound for injdctors siezing in head and a costly removal fee
But weighing it up need to look at bigger FMIC, bigger Blower and speak to rs about what else as id love to hit the 300hp mark if possible show the perv boys what torque is all about
Will be costly but im prepared to go for it lol
Threads: 142
58
No worries mate, glad you like it.
Might as well just sack the EGR off while you're there surely?
Threads: 124
26
01-10-2013, 06:27 PM
(This post was last modified: 29-12-2020, 02:57 PM by CJ_Derv.)
boost
Threads: 96
7
Oh the fun begins CJ ! XUD it and it will be all mechanical lol
Threads: 124
26
Nahh matey electronic fuel management and VNT all the way for this one now and next car when I aquire promotion next car will be perv and tvr  think my xid days are over haha
Threads: 18
Yea... fcuk pikey tuning and chucking rods :d
Seem to be having a few niggly issues I see.... all good fun!! Be intresting to see how this progresses power wise
http://pages.ebay.com/link/?nav=item.vie...1112647225
I looked into these for the 2.1 but wussed out coz of vnt control
Threads: 124
26
02-10-2013, 07:40 AM
(This post was last modified: 02-10-2013, 07:41 AM by CJ_Derv.)
(02-10-2013, 12:27 AM)Arron Wrote: Yea... fcuk pikey tuning and chucking rods :d
Im pretty sure its egr related now has to be as its got all its grunt but then bit laggy and been doing much research on the m9r engine and common faults on renault forum I got banned in less than 2 days has hundreds of problem threads all relating to the egr so gona clean it next week
(02-10-2013, 07:03 AM)Piggy Wrote: http://pages.ebay.com/link/?nav=item.vie...1112647225
Id be getting new matey  its not a 306 haha
new is about 450...which still aint all that bad
