Megane RenaultSport 2.0 DCI175 **Back Boostin**
File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
#91
(25-09-2013, 07:45 PM)CJ_Derv Wrote: Its not easy tbh I need to redo a few bits as didnt have a geat gun so had to use hairdryer but better with heat gun so can really stretch it Smile
Careful over heating it mate otherwise it seems to just let go and stretch a lot suddenly.
#92
I know what u mean pal, I found that out when I did the 306 interior first time round tbh this wrap was too thick its exterior wrap and is harder to manouver so not ideal for out handle shape but will but some better stuff and redo didnt really take that long tbh
[Image: J5hxCcC.jpg]
#93
http://youtu.be/KDgpJ0EfSOU
Airbox chop done
[Image: 20130928_123649.jpg]
Garrett GTA1549LV
Needs a bigger turb Smile
#94
Interesting, didn't know they ran a 1549VL...
Watercooled cartridge!
Get a GTB2056VLK on Wink
#95
Sorry for not being with the kids, an airbox chop? Is that just shortening the airbox length due to it being way to big when std?
Progressing well mate Smile
[Image: siggy1.jpg]
#96
Il look into that ruan will that just be a straight swap you think? Would have to get another map done obv but not too clued up on GTA's
Air box mod is basically cutting a square out of the original air feed in corner of box makes a huge difference very noisy not sure if too noisy yet havent decided
#97
amazing what modern designed heads/pistons and injection systems can do with a gt1549!!
Not slating! But that clatter at idle ιs obscene! Quietness down a hell of a lot when reved though! What torque ιs ιt pushing?
[Image: SDC10442-1.jpg]
#99
(28-09-2013, 06:13 PM)Jonny b Wrote: Not slating! But that clatter at idle ιs obscene! Quietness down a hell of a lot when reved though! What torque ιs ιt pushing?
It should be around the 350 360 mark pal
Cool!! Do you know what the limit ιs for these engines? You gonna push for more?
The standard air inlet pipe is very restrictive, hence people cut the corner out of the box removing the inlet restriction Smile generally frees up a few ponies too!
Thanks CJ and Ed, I understand the mod now.
CJ..any better for it?
[Image: siggy1.jpg]
(28-09-2013, 06:25 PM)Jonny b Wrote: Cool!! Do you know what the limit ιs for these engines? You gonna push for more?
Il find out I guess no one had gone past 212bhp and 350ft lbs as far as I know
(28-09-2013, 08:21 PM)devils_fuel Wrote: Thanks CJ and Ed, I understand the mod now.
Initially yess improved pickup and feels bit more torquey and loud but then have the issue of throttle sensor more often now so cant get full throttle and its pissin me right off changed fuel filter too and got to clean egr and see if that makes a difference  but must be throttle sensor
(30-09-2013, 02:16 PM)CJ_Derv Wrote: Initially yess improved pickup and feels bit more torquey and loud but then have the issue of throttle sensor more often now so cant get full throttle and its pissin me right off changed fuel filter too and got to clean egr and see if that makes a difference but must be throttle sensor
PITA, rip it all out and XUD it Smile
[Image: siggy1.jpg]
CJ I think there is an issue with some of the sensors working loose on the inlet mani, which may be the cause of your problems... Might be worth looking into x
Could make sense as it doesnt seem to be boosting all the time gona plug it in tomorrow and have a look around pal thanks for help buddy
Can tell when its boosting and not with exhaust tone since dpf removal although launch on insta shows boost
Had a reset on ecu and seems ti be back boosting but not too sure if back to scratch somwthings still holding back think its got to be egr as everything cleared and still lagging
You seem to be making pretty good progress with this mate, like what you're doing! Still not my cup of tea though, but if you like it, thats what counts. I also echo Darrens comment, at least its a derv! lol
One other thing, Liam also picked up on it, you need a new sig. So i made you one while i was bored. Big Grin
[Image: Untitled-1_zps32e9045e.jpg]
Hope you likey! Wink I won't be offended if you'd rather make your own, and dont use mine. Honest. Tongue
(28-09-2013, 06:05 PM)CJ_Derv Wrote: Il look into that ruan will that just be a straight swap you think? Would have to get another map done obv but not too clued up on GTA's
Yeah, you'd need another map done, but in their stock application they make ~220hp - the GTBs are such incredible turbos for their size...
Should be able to see ~280-290hp at a guess, maybe even more - and they spool up stupendously quick!!
Probably the sweetest turbo for a ~2.0 engine if you want outstanding driveability.
(01-10-2013, 01:15 PM)WiNgNuTz Wrote: You seem to be making pretty good progress with this mate, like what you're doing! Still not my cup of tea though, but if you like it, thats what counts. I also echo Darrens comment, at least its a derv! lol
Yeah gettin there with it pal seem to have ironed out the problem of turbo not boosting its back boosting but we believe the egr to be causing the lag so before dyno it will be gettin stripped down and cleaned
Thsts wicked matey il use that when im next on laptop nice one not got photoshop back on lappy yet cheer fella
Can you not get the get sacked off and mapped out?
I thought I mite need a map going to speak to RS Tuning in leeds and weigh up a decent size GTB and then look at getting the injectors refurbed or uprated but the M9R are renound for injdctors siezing in head and a costly removal fee
But weighing it up need to look at bigger FMIC, bigger Blower and speak to rs about what else as id love to hit the 300hp mark if possible show the perv boys what torque is all about Smile
Will be costly but im prepared to go for it lol
No worries mate, glad you like it. Smile
Might as well just sack the EGR off while you're there surely? lol
boost
Oh the fun begins CJ ! XUD it and it will be all mechanical lol
[Image: siggy1.jpg]
Nahh matey electronic fuel management and VNT all the way for this one now and next car when I aquire promotion next car will be perv and tvr Smile think my xid days are over haha
Yea... fcuk pikey tuning and chucking rods :d
Seem to be having a few niggly issues I see.... all good fun!! Be intresting to see how this progresses power wise
S2 HDi >click<
154bhp
280lbs/ft
http://pages.ebay.com/link/?nav=item.vie...1112647225
I looked into these for the 2.1 but wussed out coz of vnt control
(02-10-2013, 12:27 AM)Arron Wrote: Yea... fcuk pikey tuning and chucking rods :d
Im pretty sure its egr related now has to be as its got all its grunt but then bit laggy and been doing much research on the m9r engine and common faults on renault forum I got banned in less than 2 days has hundreds of problem threads all relating to the egr so gona clean it next week Smile
(02-10-2013, 07:03 AM)Piggy Wrote: http://pages.ebay.com/link/?nav=item.vie...1112647225
Id be getting new matey Smile its not a 306 haha
new is about 450...which still aint all that bad
  Megane 265 Lwilliams 13 9,346 01-04-2017, 06:59 AM
Last Post: Matt-Rallye
  Megane 230 R26 - detailing content ginge191 69 53,721 22-04-2016, 09:18 PM
Last Post: ginge191
