boot lock inter' fault
so weird one...
ph3 boot lock, so no key.
it jammed on locked at castle combe, so I got in via back seats and popped it open.
then it worked fine for a day. this went on for a week.
Got bored of it. So checked wiring loom between body/boot. Looks like new.
Checked lock. Seemed sticky, so stripped down, greased up and it was loads freer. Tried it dozen times and all well.
A car journey later and it did it again.
So swapped lock servo motor.
And its done it AGAIN! grrrr.
what am I missing here?!?!
long shot . . . the rubber adjustable things at the bottom corners of the boot, maybe screwed out too far and holding it tight? like i say long shot . .lol
I'll have a look! I'll take a long shot!
Not sure this is of any help but here we go,
Had this on my phase 1.
Have you taken the locking unit apart?this:[Image: peugeot-306-boot-hatchback-locking-motor-120-p.jpg].On my phase 1 there was a nylon cog that is connected to the motor.One of the teeth on the cog had wore and occasionally would jam.this might be your problem.
I bought a refurbished one on egay for about a tenner.
thats the servo motor.
replaced it already. Same fault occurs
Did you check the loom all the way back to the plugs in the rear quarter? If its a new loom might not have been pushed in tight. There's also an earth point around there somewhere iirc.
bugger
turns out that I have two buggered servo motors!!!
So, now WANTED: boot servo motor!!
WD40 the shit out of it tbh!
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
tried that!
(25-09-2013, 05:20 PM)Piggy Wrote: bugger
I was right lol
Ebay and you'll be reet!
Are phase 1 and 3 servo motors the same? If they are I've got a working servo motor in the black d turbo you have the rad from Smile
PH1 FTMFW!
yeah they are.
sorted now tho ta!
