Broken gti6, update/help?
#61
Thanks for the heads up c2k, but I can see the inlet valves are bent now the inlet is off, will find out the true extent of the damage when I get the head off.
Any no what could have caused it to slip on the front cam?
What's the best way to remove exhaust manifold?
#62
Exhaust manifold can be done from above but easiest from below, it's a bitch .
Perhaps Cambelt Snapped and was poorly timed. Where did you find the pullies?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
#63
(08-09-2013, 08:06 PM)C2K Wrote: Exhaust manifold can be done from above but easiest from below, it's a bitch .
Cambelt hadn't snapped was ok, bottom end locked off and rear cam locked off fine front one was out by about 80-90degrees. The woman had the car for 4 years with out issue she said this is first problem she had apart from cat for mot.
Not looking forward to the exhaust manifold then Sad
#64
I would have thought 90 degrees beyond the possibility of a pulley slot, it's maybe 30 degrees arc of rotation I recall. to have more would indicate that it was poorly timed - perhaps someone had a go at belt before you after cambelt snappage was what I meant. Smile
