04-09-2013, 09:55 AM
Bottom ball joint on the 205 hub is oval, anyone know if 306 hubs fit or will i just need to try it?
306 hubs on 205
04-09-2013, 10:03 AM
They do fit but give possitive camber iirc
04-09-2013, 10:04 AM
Was going to say; 306 hubs fit; Dom uses them i believe.
04-09-2013, 10:18 AM
With positive camber?!
04-09-2013, 11:40 AM
Drive shaft splines are different sizes, next question do 1900 gti drive shalfts fit a 1905 xud with Hdi box?
04-09-2013, 11:44 AM
the xud/hdi box is the same splines for drivehshafts...
but dont know about gti shafts...strictlyderv would be the man to ask Wishes for more power...
When i changed from the xud to Hdi box the inner drive shalft cups need changing as the splines are too long and caused it to leak
04-09-2013, 02:29 PM
The 1.9 205's can use the 16mm ball joint hole from the 306 gti6 fine, yes it will give you about +0.5 positive camber give or take a bit.
I have a spare one if you need it to keep you going on for a while ? Which side do you need ?
04-09-2013, 03:06 PM
(04-09-2013, 11:46 AM)Daniel306 Wrote: When i changed from the xud to Hdi box the inner drive shalft cups need changing as the splines are too long and caused it to leak the boxes are basically identical pal. just the final drive and clutch arms that are different Wishes for more power...
(04-09-2013, 02:29 PM)Bender Wrote: The 1.9 205's can use the 16mm ball joint hole from the 306 gti6 fine, yes it will give you about +0.5 positive camber give or take a bit. Got it sorted now used a gti hub and put my original ->insert name of part here that has got the threaded holes for the wheel bolts and splines on the inside for the driveshalft<- with a new bearing (04-09-2013, 03:06 PM)Piggy Wrote:(04-09-2013, 11:46 AM)Daniel306 Wrote: When i changed from the xud to Hdi box the inner drive shalft cups need changing as the splines are too long and caused it to leak Iv seen a few members on here have the same problem when converting to hdi box, the part of the shalft that the seal run's on can be different and will weep oil out
04-09-2013, 07:09 PM
04-09-2013, 07:23 PM
well done chap. nice n sorted
![]() likely they wept oil because the seals maybe werent replaced?? Ive got hdi box on and xud shafts. new seals and no leaks Wishes for more power...
04-09-2013, 08:25 PM
04-09-2013, 09:04 PM
When you say gti, did you mean gti6 hub or is your car the 1.6, bit confused ?
04-09-2013, 09:26 PM
(04-09-2013, 11:46 AM)Daniel306 Wrote: When i changed from the xud to Hdi box the inner drive shalft cups need changing as the splines are too long and caused it to leak Disk cutter ![]() ![]()
04-09-2013, 09:59 PM
(04-09-2013, 09:04 PM)Bender Wrote: When you say gti, did you mean gti6 hub or is your car the 1.6, bit confused ? Mine is a Dturbo, I used a 205 1900 Gti hub with the original hub face (04-09-2013, 09:26 PM)Dave Wrote:(04-09-2013, 11:46 AM)Daniel306 Wrote: When i changed from the xud to Hdi box the inner drive shalft cups need changing as the splines are too long and caused it to leak Have you seen this happen before?
05-09-2013, 11:38 AM
So 205 hubs could give negative camber on a 306, hmmm..?
05-09-2013, 08:55 PM
it's because the bottom of the carrier is longer on a 205, but if you run 309 front arms it stops this.
07-09-2013, 06:01 PM
I don't want to stop it, i want negative camber!
